Yamaha M-35 troubles
nguyendot
So I have a pair of M-35 stereo amps that I love. They're low powered and I plan on using them to bi-amp a pair of speakers someday. The problem is one of them has no/scratchy output on the left channel. It cuts in and out by itself and sounds scratchy when it happens.
I really want to have it repaired. What should i look for inside if I can maybe fix it myself? If not, where can I take it that wont cost an arm and a leg?
Main Surround -
Post edited by nguyendot on
just checking to see if your did the channel swap L-R and R-L
to confirm it is the amp and not in the speakers or source. -
The cutting in and out might indicate a wonky relay.Testing
Testing
Testing -
I did swap, it is definitely the amp. If i switch it into 4 channel mode, only the pair on that side work as well.
What can I do about a wonky relay?Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Keep in mind that is only one possibility,it could be somthing else entirely.If it is the relay it would need to be replaced, but you could try resoldering the pins to the PC board as it might be just a cold solder joint.
What can I do about a wonky relay?Testing
Testing
Testing -
I will definitely look into that. I may look at the solder points on this amp and see if i can fix it. Can a bad or rusty pot cause this too? It has 2 volume controls and if i mess with that channels volume controls I can sometimes get it to come back, but only at full volume.Main Surround -
Yes if thats the case then I would take a closer look at that pot.Try bypassing it and see what happens.Can a bad or rusty pot cause this too? It has 2 volume controls and if i mess with that channels volume controls I can sometimes get it to come back, but only at full volume.Testing
Testing
Testing -
excuse my ignorance, how do i do that?Main Surround -
Desolder the signal input and output pins of the pot or (remove entirely) and replace with a wire jumper.If you can post a pic of the pot and how it is mounted I might be able to give you further guidance.Testing
Testing
Testing -
Will do when I get time this weekend. Headed out of town right after work today. But I definitely want to get this fixed. I love having a matched pair of amps.
I understand exactly how this troubleshooting (logically) works, but not how to go about it.
Let you know as soon as i can.Main Surround -
It's the volume control pot....same exact problem with the one I had . Since the amp only had spring type speaker connections in the rear, I gave it away to a friend.....he fixed it by replacing the pot.The first rule of Fight Club is you don't talk about Fight Club -
just another thought
did you try the special spray cleaning and lubricating the volume pot
I forgot what another post suggest DeTox Gold
I'll search for the name. -
plain DeOxit and DeOxit Gold.
The first cleans the second conditions the contacts. -
Where can I get it from?
Also, why is his power LED blue/white? I'd love to change mine to that color.
Also, if I were ambitious, could i change out the speaker connectors for 5 ways?Main Surround -
I have not used this product but similiar cleaner/lubricant product
here is the url that I found regarding DeOxit $9.99
http://www.radioshack.com/product/index.jsp?productId=2104746 -
appears to be out of stock online
check local stores... -
THanks, will try that when i get home saturdayMain Surround -
I tried deoxit and it did nothing, the channel is still dead. It doesn't even scratch anymore, it just doesnt have any output whatsoever. I have no idea what to do, i'm not that into the circuits and stuff.Main Surround -
