why Direct is better than Stereo?
SivaNevets
SivaNevets Posts: 303
edited July 2009 in 2 Channel Audio
theres a noticeable difference in sound quality between "Direct" and "Stereo" mode from my Denon 789 receiver. Direct is more natural, smooth, but i cant use the subwoofer. With Stereo i can use the sub but the sound quality is more edgy and theres disturbing sibilence(:D).
why i cant just use the subwoofer with the direct mode? why are these 2 so different?
Front: Martinlogan ESL
Center: Martinlogan Stage
Rear: Martinlogan Motion 4
Sub: Martinlogan Grotto-I
Receiver: Pioneer Elite SC 1523K
PC 2 Channel: Polk LSI7
Headset: Grado RS2 + Grado RA1 amp
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
Pioneer 8200BT HU
Post edited by SivaNevets on
  • concealer404
    concealer404 Posts: 7,440
    edited July 2009
    Stereo mode incorporates processing by your Denon. It handles the split between the mains and the subwoofer. With direct, it's simply a direct pass through, signal isn't touched from your source to the speakers. The receiver simply amplifies the existing signal, and doesn't mess with it.
  • BlueFox
    BlueFox Posts: 15,250
    edited July 2009
    Run your sub off the front pre-amp output jacks.
  • Conradicles
    Conradicles Posts: 6,371
    edited July 2009
    Or...don't use the sub and use direct.
  • SivaNevets
    edited July 2009
    thx...i guess my soundcard and dac has already mess up with the signal enough..
    and BlueFox, can u be more specific? my avr has no pre-out
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    Pioneer 8200BT HU
  • BlueFox
    edited July 2009
    SivaNevets wrote: »
    Then I guess that option is out. Does you sub support direct wiring to the speakers. That is, you run the L/R speaker wire to the L/R speaker in posts on the sub, and then run the L/R speaker wire from the speaker out posts on the sub to the speakers. Some say that is the best way to wire a sub, but it is extra work.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited July 2009
    When I'm listening to music on my AVR, it's almost always on direct.
    It bypasses all of the video processing circuitry and leaves the signal untouched...it's a lot more natural sounding. Not having the sub can be a drawback, but my speakers produce enough bass for my tastes anyway. With smaller speakers, I could see the lack of a sub being a bigger drawback.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • SivaNevets
    edited July 2009
    Im using psw10 and rti6, it hink the sub supports direct wiring. Ill give it a try tomorrow.
    So i have to use the crossover button from sub now right?
    thanks
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    Pioneer 8200BT HU
  • comfortablycurt
    edited July 2009
    SivaNevets wrote: »
    thanks
    Yes, the PSW10 supports speaker level connection.
    You'll have to use the crossover on the sub then.
  • John K.
    John K. Posts: 822
    edited July 2009
    Siva, if your 789 is set and operating correctly there shouldn't be a "disturbing sibilance" on the Stereo setting as compared with Direct. Direct, as is relevant here, bypasses the tone control circuitry, but even in Stereo, if the tone controls are set at the center point, there shouldn't be the treble emphasis which would sound sibilant at times. So, are you sure that the treble tone control isn't set at an increased level? If it's not, there's a possibility that on your particular 789 the treble is being boosted even at the center setting. You might try a little treble cut when in Stereo to see if this improves matters.
    Having said all that, you can use the sub even in Direct mode if you set your RTi6s "Large" and set the sub to "LFE+Mains", which allows it to also play bass from the main channels, along with the RTi6s which are playing full-range, including the bass.
  • Knucklehead
    Knucklehead Posts: 3,602
    edited July 2009
    Ok im a little confused,(which isnt hard to do). If you use the RCA connection for your subs, is the crossover on the sub still active?
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • jimmydep
    jimmydep Posts: 1,305
    edited July 2009
    When using the LFE input on the sub you bypass sub's the internal Low Pass Filter and use the crossover on the receiver.
    Jimmy
  • thsmith
    thsmith Posts: 6,082
    edited July 2009
    My Denon 2808 has an option for the sub in Direct mode.
  • jimmydep
    edited July 2009
    thsmith wrote: »
    I don't think my Yammi 665 has that option, when you use the direct mode the sub is disabled........although that's a nice option to have.
    Are you using the LFE output on the receiver???
    Jimmy
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2009
    If it has an option, it's not really direct is it? To pull a subwoofer signal it has to process it in some way.
    Main Surround -
  • AudioGenics
    AudioGenics Posts: 2,567
    edited July 2009
    my take is for direct
  • jimmydep
    edited July 2009
    nguyendot wrote: »
    I agree with you, but I find in direct mode the low end is just a tad light.
  • Knucklehead
    edited July 2009
    jimmydep wrote: »
    Jimmy
    Ok thanks, thats what I was thinking.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • Pauly
    Pauly Posts: 4,519
    edited July 2009
    +1 on the Direct. Mine has Direct and Pure Direct. Always on Pure Direct.
    Life without music would
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited July 2009
    SivaNevets, you should set your subwoofer to both LFE ("A") and R & L ("B") speaker connections (making sure you set your crossover appropriately). This will allow your receiver to control what is sent to the sub LFE during movies and will allow Bass through your subwoofer during direct playback through the speaker and crossover connections of your subwoofer.
    Most subwoofer uses their Xo while connected on the speaker connections and very rarely during LFE use since the AVR already controls such.
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • mmadden28
    mmadden28 Posts: 4,283
    edited July 2009
    nguyendot wrote: »
    Perhaps its just an internally split signal where both the Mains and sub still get a full range signal.
    ____________________
    Pool: Atrium 60's/45's
  • thsmith
    edited July 2009
    jimmydep wrote: »
    Jimmy
    I use LFE for movies not 2 channel music although it is an option.
  • nguyendot
    edited July 2009
    mmadden28 wrote: »
    An internal analog split?
    That's what I find hard to believe.
    Main Surround -
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited July 2009
    TECHNOKID wrote: »
    Cheers!
    TK
    How would this work?
    Both LFE and pre-outs would be 'active' at the same time if both were connected at the same time to the sub.
    Unless the sub has circuitry to 'cut off' one of the inputs, then both signals will be sent to the sub. When I contacted Epik about my sub, I was told by Chad that the sub would 'sum' both signals.
    I do have two sets of cables from my sub when I want to listen in Pure Direct or watch movies, but it requires a manual swapping of cables between "music/Pure Direct" and "LFE/movies".
    If I want to watch movies, then I have my sub connected to the LFE/sub out on my AVR....fronts=small (cuz of the scary LFE effects to my bookshelves) and the AVR xover set to 80Hz. The xover on the sub is bypassed and all is good for movies.
    For serious music, I have a different memory configuration saved in my AVR for Pure Direct, fronts=Large, sub=off, and the sub is connected via L/R RCA pre-outs. I then use the sub xover to fine tune the xover freq to get the sub nicely blended with my fronts.
    Some don't like to have a sub running when going 'old school' for 2-channel listening, but I think for my system, I get a pretty good blending of sub and bookshelves in hooking up my sub this way.
    It does require manually swapping cables - but I've learned to deal with it and enjoy the flexibility.
    I'm too poor to get a preamp with HT bypass.
    I guess some AVRs might have analog bass management??? This would be the ONLY way I can think of to have the sub on in Pure Direct?
    ymmv...
  • TECHNOKID
    edited July 2009
    Nothing really hard to believe there. AVR today uses a lot of processing for the video portion which is not necessary during 2 channel/stereo listening. A simple relay would re-route the signal directly thus avoiding the processing path that is normally used for movie watching.
    Cheers!
    TK
    DARE TO SOAR:
  • TECHNOKID
    edited July 2009
    Erik Tracy wrote: »
    I do have two sets of cables from my sub when I want to listen in Pure Direct or watch movies, but it requires a manual swapping of cables between "music/Pure Direce" and "LFE/movies".
    ymmv...
    Looks like you have a pretty good hang of it. Like I said, if you use your "B" channel to drive your sub during pure direct listening (simply set it to large) since the LFE isn't present during pure direct, there is no sum since only speaker level gets the signal. Then when watching movies you set your AVR to A only (not AB) and therefore get only bass through LFE considering your A channels would be set to small. Programming your pure direct is also a good option.
    Cheers!
    TK
    DARE TO SOAR:
  • Erik Tracy
    edited July 2009
    TECHNOKID wrote: »
    Cheers!
    TK
    So when you mention A and B - are you refering to the zoning option on some AVRs?
    I tried looking at this option as another way to have my cake and eat it to so to say, but when I read my AVR manual it said that when in Pure Direct, B zoning turns off....I think....gotta go check again...
    Thanks...
  • nguyendot
    edited July 2009
    I bet he means B as in using both channels of the amplifier output. Because the subwoofer doesn't actually draw any power, it won't affect the A output, but just use the signal going to it.
    Main Surround -
  • TECHNOKID
    edited July 2009
    Erik Tracy wrote: »
    Thanks...
    nguyendot wrote: »
    Erik is right, I am taliking about this extra zone which most people don't seem to use. B simply gives you an extra pair of speakers, normally people would use them as presence but as I pointed out, one could use to drive the sub during the 2 channels listening unless Erik is right about his last point. Erik, what's the brand and model of your receiver? I use a yam HTR6080, I'll check the user manual again...
    DARE TO SOAR:
  • Erik Tracy
    edited July 2009
    SivaNevets wrote: »
    Another reason why you may notice a difference is if your Denon applies some sort of default PEQ room setting for your speakers if you ran the autocalibration feature.
    For example, for my Yamaha, the default room PEQ is "Natural".
    So if you then switch to Pure Direct, the PEQ is turned off and you just get a straight pass thru of the signals - no frequency adjustments at all.
    You may want to re-run your autocalibration and see if you can manually set the PEQ to off, save that, then compare the sound between Stereo and Direct.
    Just some additional thoughts...
  • TECHNOKID
    edited July 2009
    Check p. 33, 38, 42, 72, 78 & 93 (if B ain't working in pure direct mode when set as presence, one could set as Bi-amp and drive the sub and it should work) I guess most yams must work the same way??
    http://www.yamaha.ca/av/PDFs/Receivers/2007_models/HTR6080_Manual.pdf
    DARE TO SOAR:
