Pioneer elite sc-07 owners
leroyjr1
Does the elite receivers have a master reset feature. I'm currently not running a sub and I can't get my front speakers to play in full range. I have the sub setting turned off. I tried to find out why it wasn't playing the low notes but couldn't figure it out. It has to be something with the setting. So a master reset will let me set it up all over again and hopefully get the lower frequency to play through the fronts.
I have the fronts set to large and the center and rears set to small. It use to play the lower notes but I must have changed some settings somehow.
Post edited by leroyjr1 on
Leroyjr1
page 100 of the user manual
Resetting the system
Use this procedure to reset all the receiver’s settings to
the factory default. Use the front panel controls to do this.
Set MULTI-ZONE to OFF.
1 Switch the receiver into standby.
2 While holding down HOME MENU on the front
panel, press STANDBY/ON.
The display shows RESET NO .
3 Press ENTER on the front panel.
4 Select ‘RESET’ using /, then press ENTER on
the front panel.
The display shows RESET? OK.
5 Press ENTER to confirm.
OK appears in the display to indicate that the receiver
has been reset to the factory default settings.
• Note that all settings will beCurrent HT setup
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
Sub: Velodyne DLS-3750R
Receiver: Pioneer SC-07
Amplifier: Sunfire TGA5200
TV: Sony KDS60A2020
DBP: Sony DBP-S350
CDP: Pioneer DV-48AV
Interconnect cables: SignalCable analog II
speaker cables: SignalCable Ultra Speaker Cables Bi-wire -
