Pioneer elite sc-07 owners
leroyjr1
leroyjr1 Posts: 8,785
edited July 2009 in Electronics
Does the elite receivers have a master reset feature. I'm currently not running a sub and I can't get my front speakers to play in full range. I have the sub setting turned off. I tried to find out why it wasn't playing the low notes but couldn't figure it out. It has to be something with the setting. So a master reset will let me set it up all over again and hopefully get the lower frequency to play through the fronts.
I have the fronts set to large and the center and rears set to small. It use to play the lower notes but I must have changed some settings somehow.
Post edited by leroyjr1 on
  • olilugo
    olilugo Posts: 405
    edited July 2009
    Leroyjr1
    page 100 of the user manual
    Resetting the system
    Use this procedure to reset all the receiver’s settings to
    the factory default. Use the front panel controls to do this.
    Set MULTI-ZONE to OFF.
    1 Switch the receiver into standby.
    2 While holding down HOME MENU on the front
    panel, press  STANDBY/ON.
    The display shows RESET  NO .
    3 Press ENTER on the front panel.
    4 Select ‘RESET’ using /, then press ENTER on
    the front panel.
    The display shows RESET? OK.
    5 Press ENTER to confirm.
    OK appears in the display to indicate that the receiver
    has been reset to the factory default settings.
    • Note that all settings will be
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    Sub: Velodyne DLS-3750R
    Receiver: Pioneer SC-07
    Amplifier: Sunfire TGA5200
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
    CDP: Pioneer DV-48AV
    Interconnect cables: SignalCable analog II
    speaker cables: SignalCable Ultra Speaker Cables Bi-wire
  • leroyjr1
    edited July 2009
