Adcom GFP-715 Vibration sound with TT at higher volumes
Toolfan66
I am having vibration like sounds coming from the speakers when I am playing vinyl with my Adcom 715 PRE and my TT at higher volumes.
As a song is getting over it is very loud, the best way to discribe it is a vibration sound.
Is it possible that my Denon DL160 is not compatible with this Pre Amp?
I am very concerned here, I just hope I have not damaged the crossovers in my speakers or anything else.
Post edited by Toolfan66 on
Larry I'm not sure what you mean by "vibration sounds." Have you tried isolating your turntable? This is a myriad of isolation devices out there. I use Black Diamond Racing Cones and Isol-Pads from Quest for Sound on my turntable to isolate it from vibration.
It's coming from the speakers, and I had no problem with the Yamaha RXV-863 or the Pioneer SC-07.
It vibrates the speakers big time. -
Is it like a rumbling sound?
Does it sound like an electrical oscillation, like something abnormal is happening to the signal, or are the drivers moving in and out visibly?
Does it occur when you're on the lead in or lead out groove, or just during a track?
Can you put your hand on the plinth and stop or minimize the sound?Wristwatch--->Crisco -
sub sonic filter? I have read about this problem on here before and they said it was because the warp-age of the record and said a sub sonic filter would clear it up, or I need more coffee.
TOOLFORLIFEFAN wrote: »Yep!! you hit the nail on the head.
I think you need to isolate your turntable that is decouple it from the stand especially if what Ben asked above occurs. You also might want to consider checking the platter bearings to make sure the platter isn't wobbling. -
It seems to occur on the lead out groove.
I was listening to Nazerath's Hair of the Dog ( First Track ) as the song was ending the vibration/rumbling sound scared the **** out of me.
When I get home I will put my hand on the plinth to see if it stop's or minimize's the sound. -
Subsonic filter or better isolation for the table."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
Subsonic filter should be on if it's available on the pre. I am guessing it's feedback caused by vibration and positioning. Try better isolation of the TT, and also try moving the TT so it's not in the direct path of the sound waves from the speakers.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
TOOLFORLIFEFAN wrote: »It seems to occur on the lead out groove.
I'd have to guess that it is subsonic rumble (that's just what it's called, I too know that you can damn sure hear it!), like the others have said your best bet is to start optimizing the table's placement. The biggest thing I found to cause it in my set up was having the platter not be completely level. After that, making certain the system was isolated from airborn and mechanical vibrations was the next step.Wristwatch--->Crisco -
Thanks Strider,
I will look into this when I get home. I will have to order some isolation pads, wether i need them or not I will get them.
Larry. -
A Herbies TT mat and some Herbies dots under the TT feet might do the trick. A Herbies TT mat eliminated a very slight 45 rpm rumble on my TT.DKG999
Is this just at loud volumes Larry? Never had this problem with my Technics 1210.
Well I havent spent a lot of time with the vinyl since I moved everything upstairs, so I am not sure I just shut it all down ASAP once I heard that noise.
I knew I would get some direction here on what it might be.
I am still wondering if the DL160 is not compatible with the phono input on the PreAmp. With it being a moving coil and all, but I can not find anything about that with the Adcom.
EDIT: I just found this, so that is not it.
GFP-715 also has a high quality phono stage that accepts signals from Moving Magnet and High Output Moving Coil phono cartridges allowing the listener to enjoy their favorite analog recordings.
So I will continue with the suggestions above when I get home. -
Do you have the dust cover attached to the TT? I have found that to be a big issue with my TT. I have disconnected it and just sit it on top when not in use. No Rumble.I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
MillerLiteScott wrote: »Do you have the dust cover attached to the TT? I have found that to be a big issue with my TT. I have disconnected it and just sit it on top when not in use. No Rumble.
I do, but why did I not have a problem with the Pioneer SC-07 or the Yamaha RXV-863? This is what has been having me scratch my head. -
TOOLFORLIFEFAN wrote: »I do, but why did I not have a problem with the Pioneer SC-07 or the Yamaha RXV-863? This is what has been having me scratch my head.
The 715 has a better phono stage......probably a lot more sensitive."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
May be they have some built in subsonic filtering.
Try just holding the dust cover to dampen it in the suspect parts of your listening to see if that is your issue.
ScottI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
I agree wholeheartedly. -
I was thinking that as well but was not 100% sure.
I have some work to do for some of the guys here;) Then I will play with it if I get some time tonight. -
Thanks for the help here guys.
I got some Iso Pads, and leveled everything out. All systems go!! Took care of my problem.
Larry. -
Good to hear.
