surrounds to match SDA/SRS2's
Polkie2009
Polkie2009 Posts: 3,834
edited August 2009 in Vintage Speakers
Wanting to see if I should stick with looking for older Polk speakers (Monitor 10's etc..??) that would match up with the mains or try something newer. Will probably be running surrounds with an amp pushing at least 100 wpc at 8 ohms.
Post edited by Polkie2009 on
  • Knucklehead
    Knucklehead Posts: 3,602
    edited July 2009
    Im thinking if you could find a pair, the MONITOR4's would match up well. Im sure guys with much more knowledge than myself will chime in. Good Luck.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
    Tony M Posts: 11,727
    edited July 2009
    Any Polks Sounds good to me.Just try to match the tweeters. I have the same mains as you and also a pr. of SDA-CRS+ I plan on using some day.:rolleyes:
  • Conradicles
    Conradicles Posts: 6,377
    edited July 2009
    5.1 or 7.1 surrounds?
  • Polkie2009
    edited July 2009
    Til more dvds come out that support 7.1, looks like 5.1 or 6.1 for now.
  • maandjojo
    maandjojo Posts: 293
    edited July 2009
    I have a pair of SRS2's for mains and use a sda crs with rdo 194 tweeter uprade. Works real well.
    Joe
    Joe
  • Polkie2009
    edited July 2009
    That sounds like a sweet setup Joe,you're the 2nd person to recommend those sda/crs for surrounds. I was reading that since my sdasrs2's have the pin/blade interconnect, that they are actually 8 ohm speakers??? I haven't installed my interconnect cable ,wasn't sure if it's a good idea since I'm running 5.1 now. I'm getting by just using old some Atlantic Technology 254.1 surrounds for now.
  • gdb
    gdb Posts: 6,012
    edited July 2009
    Plug in the I/C cable, without it you're not getting the SDA effect, in fact when it's connected, try disconnecting your center and see how it sounds. When they're set up right, SDAs create a "phantom" center.:)
  • maandjojo
    edited July 2009
    Actually I'm running crs' for the surrounds and center channel. They really work well together. I have an extra crs with rdos' you can use for a center channel. If your interested send me a pm. I do not want to discuss it any further here, its not the place for that.
    Joe
    Joe
  • Ron Temple
    Ron Temple Posts: 3,212
    edited July 2009
    Polk65 set me up with modded M4s, M5jrs with 1/2 a CRS crossover, RTA 8Ts and CRS+ to try as surrounds for my 1Cs, they all featured matching drivers and the SL2000. I preferred the CRS+ as surrounds, though the M5jrs were stellar too. When I finally gave him back his speakers, I replaced them with 2Bs w/RDOs. They work as well as the CRS+s, but add some bass in the back. I don't have room for a CRS+ center, but the CS400i works very well and does fit. I use the IC for both the fronts and the backs.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • thuffman03
    thuffman03 Posts: 1,325
    edited July 2009
    IMO matching up your surrounds is not really needed. I have never had a set of speakers in the front that are the same brand as the back. Currently I am running a Definitive Technology center, Thiel CS 3.5's in front and Advent's in the back. Your fronts and center make the most difference. Your surrounds IMHO don't make the HT.
    As long as you have a good center, fronts and sub the rears only fill in when the movie needs. As long as they are decent speakers you should be fine.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • Polkie2009
    edited July 2009
    I'm running a CS400 for the center right now. I'll hook up the interconnect cable for the SDA's fronts and see how they sound with and without the CS400 in the mix.My room is about 25'X35'X9' with a open kitchen on the side that's about another 15X25'X9'. Yea,I know,need more watts,lol.
  • Phil Dawson
    Phil Dawson Posts: 288
    edited July 2009
    You could try another pair of SDA/SRS 2s. It really sounds great when all four or even 5 (if you can pull it off) of the speakers are the same. This is especially true for 5.1 MUSIC.
    Good Luck, Phil
    SRS-SDA Front w/tweeter upgrade
    2 cs400i Center
    SRS-SDA Rear
    Shure 12in sub
    B&K ref 10 pre-pro upgr to ref 50
    Techniques 1200 TT
    Mac MR71 Tuna
    Lexicon rt-20 uni player
    HK citation pre for TT
    2 PSE Studio Mono Blocks
    4 PSE Studio Stereo Amps
    1 Mac 2100 Amp for sub
  • Polkie2009
    edited July 2009
    Wow Phil, I never thought about getting another pair of the SDA/SRS2's:)
  • chandler9a
    chandler9a Posts: 878
    edited July 2009
    Another set of sda srs' would be great! if you don't want to spend the money right now i would also suggest monitor 5s or something similar. I got mine to match my 2A's and they sound awesome.
  • Polkie2009
    edited July 2009
    I'm already looking to get some used Polk LS50's here and probably run them with a used Adcom GFA-545 amp. Still going to look for a bigger amp for the SDA/SRS2's up front. I started out checking out for the old Polk Monitor 10's,but saw the LS50's and the reviews were good. :)
  • jcmccorm
    jcmccorm Posts: 103
    edited August 2009
    Hey guys, don't mean to hijack, but since the OP asked the same question I was going to, I'll just latch onto this one :)
    I'm building a theater and I've got SDA SRS's for the mains and want to go 7.1. I've used a Boston Acoustics VR12 for the center with the SDA's and it works well. I had been using SDA1C's for the surrounds in my last theater but this time around I'm going for maximum WAF so the SDA's will going behind a false wall and I need to put the surrounds and backs into a column. I notice Polk has some in-walls that I could use for the backs and the Lsi F/X would fit into a column for the surrounds. ANyone know if these would match ok? Any other suggestions (for speakers that would fit into a column?)
    Thanks!
    Cary
  • TroyD
    TroyD Posts: 13,124
    edited August 2009
    Blasphemy.
    BDT
  • jcmccorm
    jcmccorm Posts: 103
    edited August 2009
    Well look on the bright side. I've got two pairs of SDA 1C's for sale now :)
    Cary
  • Paden501
    Paden501 Posts: 286
    edited August 2009
    I think it's hillarious that half of us here would be (or are) thrilled just to have a pair of SDAs, and the other half are using them as surrounds!!
    Monitors will do you good. 4s or 5s (tweeters to match your fronts) are the way to go.
    About the center: I'm using the 'phantom center' approach also. I have a CS350LS that I had been using as a center but I've not been using it lately. The only tricky part about going w/o a true center is that voices can sound a little quiet when there's a lot of action going on... since most of the voices in a dvd are piped through the center channel that you now don't have, you lose their volume a little bit sometimes.
    ~Matt
    My System
    Front L/R: Definitive BP10Bs
    Surrounds -Polk Audio Monitor 4As
    Preamp: B&K Reference 20
    CD: Jolida JD100a
    L/R Amp: Carver TFM-24
    Turntable: Pioneer PL-516 W/ Shure M97xe
    TV: Sony 52" XBR9
