Should I go Bi?
bikerboycb650
bikerboycb650 Posts: 9
edited July 2009 in Speakers
I am only running a center, sub, and the left and right speakers. My receiver has a setting for Bi-amping and was going to try it.
1) What are the pro's and con's?
2) Since I'm not using the surround speakers is it even worth it?
3) Can I damage my speakers since they are only 80 watts?
4) Also I removed the gold connector on both set of plugs, is this all I need to do to the speakers?
I'm still somewhat new here, so most of this is new to me.
My (small) Setup
M30 x 2
CS1
PSW10
VSX-918V Receiver
Post edited by bikerboycb650 on
  • tcrossma
    tcrossma Posts: 1,301
    edited July 2009
    You could try it I suppose, but you probably won't hear an improvement. You won't damage your speakers so long as you keep the volume level reasonable. And yes, removing the jumper between the binding posts is all you need to do on the speakers.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • bikerboycb650
    edited July 2009
    tcrossma,
    Thanks for your help. I will try. I noticed that I lost some of the settings on the Pioneer when I set it to BI-amp. I guess it can tell Im not using the rear speaker.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited July 2009
    TC is right, and I also agree with his comment on not noticing much of a big diff. Bi-Amping with an AVR does not double the power going to your speakers. You AVR gets it's power from one amp and the power is split up between the channels, but does not double when you Bi-Amp since you are using the same power source. IMO, it isn't worth the cost of the extra speaker wire, but feel free to try it and see what happens. Welcome to Club Polk btw.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • bikerboycb650
    edited July 2009
    wutadumsn23,
    Thanks, I will try it tonight.
  • Upstatemax
    Upstatemax Posts: 2,738
    edited July 2009
    I have my Monitor 70's "bi-amped" from my Denon 2808 and I noticed a difference... Mostly in 2ch music, better seperation and the bottom end filled out some more.
  • AudioGenics
    AudioGenics Posts: 2,567
    edited July 2009
    it can be additional costs to bi-amp
    but usually you gain in performance and response
  • Shicks18
    Shicks18 Posts: 397
    edited July 2009
    you will at least double your chances of getting some action. so yea, there is a possible improvement when you go bi
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Front Amp: Parasound HCA-1000A
    Center Amp: Marantz MA500
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
    Games: Xbox360 and PS3
  • nikolas812
    nikolas812 Posts: 2,915
    edited July 2009
  • Systems
    Systems Posts: 14,873
    edited July 2009
    Any thoughts on which produces better sound? Bi-Amp or Bi-wire?:confused:
    Testing
    Testing
    Testing
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited July 2009
    You probably should have thought out the title of this thread a little more...:p:p
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Ricardo
    Ricardo Posts: 10,636
    edited July 2009
    You need to try everything in this life. Once you're gone, it will be too late and you won't know if you missed something good
    SOPA
  • blueboxer
    blueboxer Posts: 621
    edited July 2009
    ken.paduch wrote: »
    Most people on this forum and others have decided through trial and error that both provide minimal improvements in most systems unless you are going fully active with your bi-amping. I have done neither in my home theatre systems, but did try both in my vehicle and noticed minimal if any improvements. I also heard a car with fully active bi-amping and it sounded very nice, but we never set the car up any other way, given the quality components used, I think the system would of sounded great with a traditional setup.
  • bikerboycb650
    edited July 2009
    edited July 2009
    M30s are actually rated to 100 watts RMS each. It would be a bit hard to tax them. I've run them once or twice on a Denon AVR 2807 (110/channel X 2) in pure audio mode almost to clipping and they did fine!
    I've bi-amped M70s with a Denon as well and couldn't hear 'any' real difference. But as soon as I brought in the Adcom 555 for 2 channel...well....that was a DIFFERENCE! BIG-time! The M70s sounded like a NEW Speaker! A formidable challenger to lower end Rti towers for 'music'! In fact, I would say the Ms have it!
    cnh
  • george daniel
    george daniel Posts: 12,096
    edited July 2009
    Try it, once you're gone,you can't come back,,;)
