Amp for 2x12" SR's
Jak3
Ok so ive had just one 12 inch SR for a few weeks now and im thinking about buying the second, i currently have a kicker 750.1 amp working the 4ohm DVC SR wired to 2 ohms, i plan on doing the same with the second SR so im gonna have to go 1 ohm... Now the problem: Im having a tough time finding an amp that can push these puppies, all i can find in the right watt range is Hifonics stuff, what else is there?
I would like to stay with kicker but those amps dont support 1 ohm and i dont wanna buy another 750.1 because i dont want to run 3 amps (I have a hifonics amp running my components).
Quality amp that will push at least 1400rms hmm?
Post edited by Jak3 on
I wouldn't run the SR's at 1 ohm, but it is up to you.
The SR's are not made to be bass thumpers and I think you will be surprised at the sound difference between 1 ohm and 4 ohm. Try running your current SR at 8 ohms once to see if you can hear a difference. I think it's less boomy and blends in better. If your goal is to have thump then you might want to look at a different sub.
A lot of people think they are getting way more output because of more watts at 1 ohm but that's not true, higher ohms are more efficient. The best way I've heard it described is a fan with 1 blade has to spin faster compared to a fan with 4 blades to produce the same amount of air flow.
And, if you run the 2 SR's at 4 ohms you wouldn't have to worry about another amp.HU: 880PRS
Front: SR6500
Amp: Alpine MRV-F545
Sub: SR124-DVC
Amp: Alpine MRD-M1005 -
My one 12 sounds pretty good, spl and sq at 2 ohms. Ive read nothing but people explaining it as being great in both departments.
Anyway ive decided im just gonna get another kicker 750.1 and run one to each sub at 2 ohms each. -
I couldn't imagine a second 12 in my Z, but go all out and let us know how it sounds.
i have the Alpine PDX 1.1000
its actually more than 1000 RMSZ
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
