speaker recommendation
drbyers
I just bought a new Honda CR-V (I've yet to pick it up) and have been told that the OEM speakers really suck.
Can anyone recommend a speaker set-up? I've since learned that the CR-V also has shallow speaker mounting areas.
I'm not really into ear-bleeding bass. I'd really rather hear both highs and lows, if that helps any.
thanks ahead of time.
Post edited by drbyers on
well the db 'juniors' are supposed to be a pretty shallow mount speaker... the ex3's (exiii) which were just discontinued and replaced byt he new db are also a pretty shallow mount but since they were disc. they are much cheaper (like 60% off) at your local retailers...
for good sound you're not going to need anything better than than that -- unless you want to shake the earth, and you've stated you don't.
so i'd go with either 4 EXIII or DB series coaxials or EXIII/DB components up front and a pair of the same series coaxials in back... off of a 5 channel amp -- use the sub out to push like a 200 or 300 watt sub.
kenwood makes a nice 5 channel does like 65 x 4 + 250 x 1 or something...
you can run something like one of the new 'mini'-momo 10's or 12's off of that sub out... or an alpine type S... or a JBL GT100... or something like that... it'll hit pretty good, give you a good overall even spectrum with nice sound.
that's simple, loud enough to keep everybody happy, good sounding, and cheap enough to do on a budget... but that's just my two cents on an easy to do system that's just basically a "factory upgrade".
The Artist formerly known as PoweredByDodge -
that's the exact kind of answer i was lookin' for.
... as he's running for governor of California no less --- "you can do combinations like, 'no problemo, dickwad'. "
glad to help. hit up circuit city or crutchfield for the exiii's on sale -- crutchfield.com oughta be the cheapest prices though anyway - even if u go w/ the new stuff, they're affordable, they're nice to deal with, and tech support is actually GOOD with them in compairson to somwehere like Shitdomain (sounddomain.com). The Artist formerly known as PoweredByDodge -
i actually did a search and came across sounddomain.com. It ought to be called pullyourhairoutdomain.com because it was a nightmare to navigate.
sounddomain is hard to navigate when u first start lookin at teh site, but once you've been using it for a while its actually simple as hell and i love how it has the little like pick subs and then pickthe companies u want to look at ... i dunno - it should be designed better, but for the **** low prices they charge their webmaster is prolly a 15 year old kid working out of a cardboard box in some dark alley for 3 cents an hour. their customer service and willingness to help you is equally as bad -- but everything has factory warranty and as long as you know exactly what you want, you get it dirt cheap.The Artist formerly known as PoweredByDodge
