RTI A3 or FXI A6 MAY be out of question...
CaligulaPolk
CaligulaPolk Posts: 1,650
edited July 2009 in Speakers
My living room is a open room, there is a wall on left side (Facing to the TV on the front) but other right side doesnt have a wall because there are open to kitchen room. So it means that i can not mount fxi a6 or rti a3 on sides of the wall. So it means i will have to go for three pairs of floorstand speakers.
A9 for front, a5 for side and a7 for rear? or do you guys have solution for fxi a6 or rti a3?
I may as well include speakers cost in my loan.. maybe!!! dont know yet, am figuring out now..
I am 100% BORN DEAF and No I am not kidding! :D Why am I here? My wife's hearing! :p
My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA
Post edited by CaligulaPolk on
  • VSchneider
    VSchneider Posts: 443
    edited July 2009
    Could you use ceiling mounts to hang your A3 ?
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2009
    Use speaker stands. If you go with floorstanders then go with all a5's. No need to spend the extra money on a pair of a7's when the a5's will do and be overkill for surrounds.
  • CaligulaPolk
    edited July 2009
    VSchneider wrote: »
    dont know if counter by my kitchen sink where barstools will be place and dont know if height will allow me to use ceiling mount a3's. I think a3 can be mounted in the back by sliding doors..
    Will take pics of the room after dinner..
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited July 2009
    Use some speaker stands for them. There are plenty of options out there to go with basically any room, and most of them don't really break the bank.
    As Lee said, if you do decide to go with floorstanders, go with A5's. The A7's or A9's would be overkill for surround duty IMO.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    Toolfan66 Posts: 18,061
    edited July 2009
    leroyjr1 wrote: »
    +1 on this.
    I can make you some nice hanging stands for the 3's or 6's if you want to go that route, What I mean by this is they will be stands that sit on the floor but you will hang them from the hook on the back of the speaker, and you would be able to turn them to your liking. They would pivot from the base.
    They would cost a lot more then the stands you can buy that you just sit them on. Plus you would never scratch the bottoms of the speaker.
    With that said the cost of the 6's plus the stands I could build for you, you could just buy the 5's.
    So I say if you have to, go for the 5's sides and rears.
  • CaligulaPolk
    edited July 2009
    I didnt take pics yet, kids are coming in and out of the house. I am going to take pics tonite and you all can see what my options are.
    I dont really want to use ceiling mount but its good idea.. Dont want to do damages to my new home. IF i go that route, i probably need hire someone to do it for me.
    wife said itd be easier use floorstand speakers but we also have 20 mos old son who like to push things down. Do you think he can push a5's on the floor?
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited July 2009
    Doubtful, but you never know. I'd say just go ape at get A5s for the surrounds/rear surrounds. Nothing says "wow" like six floor standing speakers :D
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited July 2009
    Ceiling mounts can work if it turns out to be your best compromise - given your constraints.
    A3s may be a bit large - what about A1s as rears? They can still pump some sound as rears. I have RTi4s ceiling mounted cuz I have no 'left wall' which is open to my kitchen and no room behind the couch.
    I got pics if interested...fwiw....
  • CaligulaPolk
    edited July 2009
    Erik Tracy wrote: »
    yes please do share... Thank you erik
  • Erik Tracy
    edited July 2009
    Here's a pic of my HT/family room:
    http://erikt.cts.com/Pictures/hometheater/RTI4-Omni-mount-2.JPG
    http://erikt.cts.com/Pictures/hometheater/RTI4-Omni-mount.JPG
    If you look to the 'right' you can just see the white framing to my back door.
    And facing that way to the 'right' is my kitchen - there is no wall to mount anything on that side and there is no room to put a speaker on a stand.
    Due to WAFs - the room layout is what it is and I had to work within those constraints to get the HT setup in place.
    Not the ideal setup....isn't to THX or Dolby specs for placement, but it works well for me.
    Polk speakers with rear power ports can easily be adapted to use different ceiling mounts.
    http://erikt.cts.com/Pictures/hometheater/RTI4-Omni-mount-1.JPG
    Some may not trust that setup, but Polk verified with me that the powerports are designed to hold the full weight of the speakers. As long as you use a mount and ceiling hardware rated to support the weight of the speaker you should be fine.
    Do what works best for your space and constraints. :p
  • CaligulaPolk
    edited July 2009
    will anyone please share info about how i can get ceiling mounts for rti a3 or a1. maybe for fxi a6 if there ceiling-pipe mount
    also... thank you mr tracy for sharing the pic and idea.
  • SivaNevets
    SivaNevets Posts: 303
    edited July 2009
    Eric,
    which bracket is that? Im wondering if the RTI6s r mountable. How did the RTI4 attaching to the bracket?
    Do you think this will work for RTI6?
    http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082804&p_id=5558&seq=1&format=2
    Thx
    Front: Martinlogan ESL
    Center: Martinlogan Stage
    Rear: Martinlogan Motion 4
    Sub: Martinlogan Grotto-I
    Receiver: Pioneer Elite SC 1523K
    PC 2 Channel: Polk LSI7
    Headset: Grado RS2 + Grado RA1 amp
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
    Pioneer 8200BT HU
  • CaligulaPolk
    edited July 2009
    I took pictures of my living room... before and after (photoshopped) Take a look and give me your suggestion... Decoration is not decided yet.. just messing around til we decide what decoration we want put up. stuff still in boxes.
    BEFORE...
    I also have two ceiling speakers that came with the house.. dont know what brand.. Dunno if it will match polk speakers
    After Photoshopped
    surrounds RTi a5 (if i am not going for fxi a6 for side speakers)
    Fxi a6 with ceiling mount / pipe? (if i am not going for Rti a5 for side speakers)
    RTI a3 mounted (if i am not going for RTi a5 for side speakers)
    RTI A9 and CSi a6 and we will have new tv stand soon...
  • SivaNevets
    edited July 2009
    nice renderings upstairs :D
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    Pioneer 8200BT HU
  • CaligulaPolk
    edited July 2009
    SivaNevets wrote: »
    ?? there is no 2nd floor?
  • Erik Tracy
    edited July 2009
    The mounts are the Omnimount20 - holds up to 20lbs.
    The Omnimount ball has a threaded end that fits nicely in the powerport keyhole.
    But - I adapted it by creating a washer and nut 'sandwich' by purchasing two oversized washers and a 2nd nut.
    One washer and one nut go on either side of the powerport keyhole - then you tighten down the nuts from both sides.
    Works perfectly - snug, safe, and strong.
    The Omnimount was then ceiling mounted used heavy duty dry wall expansion lugs.
    This may not deemed suitable by others - but it works great for me.
  • CaligulaPolk
    edited July 2009
    do any one of you know where i can find ceiling pipe mount for fxi a6? example is on the photo where i photoshopped mount with fxi a6.
  • jimmydep
    jimmydep Posts: 1,305
    edited July 2009
    A plumbing supply house......2- 1/2" threaded floor and ceiling plates with a 1/2" x ?? black steel nipple, 1- can of black spray paint.....if you can't find it let me know and I'll send them to you, I have plenty of them in my shop.
    Jimmy
  • Erik Tracy
    edited July 2009
    jimmydep wrote: »
    Jimmy
    I think what you are describing are called "bulkhead" mounts which come in different sizes and threaded to accept different diameter threaded pipes.
    With the right hardware you can ceiling mount a bulkhead mount and put in as big a pipe as you need for the strength you want. I'd use toggle bolts for something really heavy.
    fwiw....
  • sandworms
    sandworms Posts: 1,043
    edited July 2009
    consider moving the tv to the west wall and all else should fall in place
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • jimmydep
    edited July 2009
    Erik Tracy wrote: »
    fwiw....
    Nope...These are just standard plumbing parts, nothing fancy, they run about $1.50 each....Being a Plumbing contractor for the past 30yrs we use these all the time.....If you paint them with a black high gloss paint, they'll look as good as anything else you'd be able to find at a fraction of the cost.....
    I have plenty of them, PM me your address and I'll send them to you, if you give me the size of the nipple I'll custom cut it for you too.....no big deal
    Jimmy
  • mystik610
    mystik610 Posts: 699
    edited July 2009
    Your livingroom is similar to mine, except I have an 18ft vaulted ceiling and a more walls between the kitchen. I mounted my FXi3's along the back wall (per the polk diagram) and they work fine. They would probably work better mounted along the sidewalls next to the listening area, but they still create a nice sense of spaciousness mounted along the rear wall.
    Open floor plans are nice, but aren't very home theater friendly lol
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
  • CaligulaPolk
    edited July 2009
    sandworms wrote: »
    wouldnt be enough room or couch to tv distance will be closer. We are comfortable with our tv setting. Plus cable and speaker wire plate is already installed on north wall.
    so which speakers should i go for surrounds in my open space living room situation?
    rti a5's
    rti a3
    or
    fxi a6 (for side)
  • CaligulaPolk
    edited July 2009
    How would FXI a6 sound if its CEILING mounted with pipe about 3 feet down from the ceiling? if i use pair of fxi a6 sideway would i need rear speakers or FXI A6 would Diffuse surround effects using dipole mode. Set Surrounds as “small” in your receiver’s
    Bass Management settings.
  • CaligulaPolk
    edited July 2009
    anyone?
  • mystik610
    edited July 2009
    The FXi a6 would need to be mounted on the wall to diffuse the sound, as the sound waves need to be reflected off of an adjacent wall.
    My System Showcase!
    Media Room
    Living-room
    Headphones
  • CaligulaPolk
    edited July 2009
    mystik610 wrote: »
    thought so.. so rti a5 is better bet huh?
  • leroyjr1
    edited July 2009
    Why not just do a 5.1 and use the rti a3's on each side of the patio door in the rear behind the couch and be done with it? Forget the sides.
