Tried the Lotr Ring drop.. on the SVS
Hey just a fast post before bed, I purchased Lotr EE tonight, finally tried the ring drop on the sub, But what's the deal.. only 107-108db max with the volume loud!! Now the blast after the ring drop hit 110 on the money at about 9-10 foot.. Just reffering back to the pwc thread lol.. I thought with a small room like mine and the SVS surely i woulda hit 110 db.. Now im not unhappy with the SVS for this just curious with all the claims to 110db with various subs and larger rooms.. do i need extremly high volume, the sub amp cranked for the test... really i don't care its all in fun, im just wondering. Ok well i tried and failed.. close though. any better scenes to try on this dvd??
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
Are you talking about the fight at the beginning of the movie where the guy chops off his finger/hand and there is the major explosion?
If that is the scene you are refering to I do not think I have heard and bass deeper than that. -
yes where he gets his finger cut off, then after that thier is an explosion, which is really hard hitting.. I was reffereing to why my sub couldn't hit 110db on the ring drop? Dr.spec started a thread for fun to see how many peoples subs could do it, my didn't tonight.. so i was wondering.MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
the Ring drop is a boarderlined 23-22hz drop right? and the PB1 can only do that with inroom response??- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
not sure, waiting for Dr.. to chime in. Tomorrow
it did 108db so, its hit 110db on monsters inc.MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Any chance your Peak base is set to low (via your Receiver/preamp)? -
i don't have the bass limiter on, if that's what you mean?? the sub out is set to -5 and calibrated to about 78-79db plate amp to 10 O clock.. my small square room is killing me i think.. still hits crazy bass in all the dvd's i demo'ed so far..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Faster,
What Frank is referring to is something called Dynamic Range setting. Make sure that it is on max on both your DVD player and Receiver/ prepro (if they have this setting).
I'm sure Doc will get you on Specification with a good prescription there bud!
Paul
man ur hooked on them smileys arnt ya? lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Faster,
Take a look a pg 33 of your manual. There you will find the instructions for adjusting the Peak Bass Limiter on your receiver. The way it works is that the receiver will actually look at the audio signal before it is sent to the sub and limit the volume that the sub will reproduce in order to prevent damage to the sub. -
So the bass limiter is indeed something different than the dynamic range feature? Hmmm...that's one feature that none of my receivers ever had (which receiver is it??).
P. -
Faster's sig lists an Integra DTR 7.1
The Bass Peak function can be found on just about all THX certified gear, although it is not exclusive to THX receivers/preamps.
Faster,
If you didn't already know, there are also some DTS LFE output options on your receiver that you should look at as well. -
I don't have the bass limiter enabled, and the dts lfe is set to -0 options are -10 and -0
I havent played with it today, been out and about.. but thanks for the help frank. will check into this laterMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
break in you have to break in your sub. i have trubble going very far past 110 with stryke force. but if i tuned to around 20-22 it would be easly 120
ganzo ur sub is a weapon of mass destruction. i feel sorry for your neighboors, but i envy you
I agree, once broken in the sub should go where you want it...I would suggest some good cables as well which will help you acheive the bass drop you want. Bettercables are an excellent bargain and deliver the goods without spending $$$....See the Music, Feel the Music, Be the Music...
Uh-oh - here we go again on the speaker break-in topic - WATCH OUT!Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688
