tweeter upgrade
maandjojo
I believe that I would need the RDO 194s' to upgrade the tweeters on the SRS2s', is that correct?
Thank you,
Joe
Thank you,
Joe
Joe
Post edited by maandjojo on
Correct."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanx Face, and also for your pm reply. I work for an electronics company so it should not be a problem to pick up what you are recommending.
JoeJoe -
Call Polk Customer Service and place your order and tell them your a member here for a discount. Your IC is blade/blade I assume.
They are blade to blade, and I did mention to Polk yestarday that I was a forum member and got the discount. Ben had said to mention his name and I would get the discount, she almost charged me double then laughed and gave me the discount anyways. Thanks NJ.
JoeJoe -
I have the same speakers and love them. Well kind of the same. I have re-done the x-overs, applied dynamt extreme to the baskets, replaced the binding posts, tweeters and they are in mint condition to start with.
