SDA-1C XO upgrade - 750pF cap questions
I have been reading everything I can find on upgrading my 1C XO. Mainly these 3 threads.
https://shop.polkaudio.com/forums/showthread.php?t=47379
http://www.polkaudio.com/forums/showthread.php?t=57467&highlight=SDA+crossover
http://www.polkaudio.com/forums/showthread.php?t=40330&highlight=SDA+crossover
I am confused about what to do with the 750pF cap. Seems most people bypass it.
Why ?
Thanks,
Tracy
Why ?
Thanks,
Tracy
It was done to improve the SQ of the caps they were bypassing. Capacitor technology has come a long way since then and they are no longer needed. Plus bypassing can cause artifacts and smearing, you should use a single cap(value) whenever possible."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Its a bypass cap which is not needed with higher performing capacitors. Majority of people also feel they give a funky/fake/colored sound or something like that.
Face, your faster than me and more knowledgeable too!!
Thanks Face, So all I need is the 12uF HQ film cap and remove the 750pF cap ?Speakers: SDA-1C (most all the goodies)
Correct."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Silly question...but when you guys say "bypass"...that means just totally remove this little 750pf and NOT replace with a jumper wire correct?
Doing mine tomorrow and just trying to get all the facts. Thanks! -
Yes remove, and place nothing in the hole the bypass cap came out of.
Ben.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Oh whoa, over here Ben's been helping me alot in choosing my caps for my upgrade as well. There's a 750pF in there?...it wasn't in the SDA parts list sticky thread. Glad I read this post, thanks guys!Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Definately no to the wire jumper.Adding one would effectively remove the main cap(12uf)from the signal path,thus the tweets would be receiving the full frequency range.The result will be tweeter failure not to mention horrible SQ before they expire.Conradicles wrote: »NOT replace with a jumper wire correct?Testing
Testing
Testing -
Conradicles wrote: »Silly question...but when you guys say "bypass"...that means just totally remove this little 750pf and NOT replace with a jumper wire correct?
Keep us posted, I am ordering my parts today.Speakers: SDA-1C (most all the goodies)
