SDA wiring checkpoints
jimbo1421
jimbo1421 Posts: 772
edited July 2009 in Vintage Speakers
Hello,
In other threads I described a problem with my SDA-1Bs where the phantom center is much reduced; center vocals sound as if they come from a long way away. See: http://www.polkaudio.com/forums/showthread.php?t=85190 and http://www.polkaudio.com/forums/showthread.php?t=85454
Polk CS sent me a document entitled "Quick Tests To Determine Proper Functioning of SDA Loudspeakers", which describes both white noise listening tests and resistance tests between various connection points. I have done both.
I used a white noise generator from my laptop for the listening tests. My SDA-1Bs passed these tests except in one particular: The "Quick Test" file described an "odd, spacey quality" when listening to the pairs of dimensional speakers by themselves, with the balance all the way to the right or left; I didn't hear that quality; the white noise seemed to come from far left to near left, center, and near right to far right.
The results of the resistance tests are in the attachment. Notice that some of the measured values are as much as minus 21% of the reference values that I got from the "Quick Test" document, whereas +/- 10% is considered normal.
So what does this all mean? I know little about electronics; I am just following directions. Do the results of my tests account for the missing center image? Whether they do or not, what is my next step?
Regards,
Jim
PS: I would like to post the "Quick Test" file here, but it came in an email prohibiting unauthorized distribution. I have asked for permission, but have not heard back.
PPS: Unplugging the interconnect cable causes the center image to sound as expected.
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
  • jimbo1421
    edited July 2009
    bump…
    Can anyone interpret the results of these tests?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
    F1nut Posts: 52,406
    edited July 2009
    Looking at your test results, you have problems. I'd say either some of your wiring is wrong and/or something is wrong with your crossover(s).
    Also, I noted in another post that you said the drivers are MW 309's. They should be MW6509's.
    Can you post detailed pics of both crossovers with the wiring connected?
  • jimbo1421
    edited July 2009
    Thanks for your interest, F1. All the midwoofers are MW 6509s. Not sure where that 309 number came from-typo?
    It will take a few days to get pictures developed. I am still in the 35mm film age.
    Regards,
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
    F1nut Posts: 52,406
    edited July 2009
    No problem, I'll be here. 35mm still takes the best pictures.
    F1nut Posts: 52,406
    edited July 2009
    Hey, just a quick question. Do you have the right speaker on the right side, left on the left as you look at the speakers?
    Also check that you have the speaker wires connected properly, positive to red, negative to black. If they are correct, swap them. Postive to black, negative to red at low volume and see what happens.
  • jimbo1421
    edited July 2009
    Yup and Yup. I will try the swap.
    Side issue: I just pulled the bass radiators to take pictures and noticed that the styrofoam cones are mounted about 1/8" off center when viewed from the inside face through the hole in the basket. From the outside face the black circular thing is also off center with respect to the rubber surrounds. I see no signs that any of the parts have detached from each other. Is this a problem?
    Thanks again for your interest,
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • jimbo1421
    edited July 2009
    I just tried this. It has the same effect as unplugging the interconnect cable: the dimensional speakers go silent.
    Regards,
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
    F1nut Posts: 52,406
    edited July 2009
    Ok, it would seem that the phase is correct.
  • jimbo1421
    edited July 2009
    That's good. I should have pictures of the crossovers Thursday night.
    Thanks,
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • jimbo1421
    edited July 2009
    I thought we covered this already. You've got a problem and you're going to have to do some testing of cap/resistor and possibly inductor values or you could simply upgrade the caps and resistors as they are old/inferior anyway.
    Where's those pictures you took?
    I will be getting them back today; I had to work late the last few days.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • jimbo1421
    edited July 2009
    Hi, F1nut. Here are the left channel crossover pics. Right channel to follow.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • jimbo1421
    edited July 2009
    Hi again, F1nut. Here are the right channel crossovers pics. What do you think of them?
    It has been four days since I started this thread and in that time my SDA-1Bs have improved remarkably. The center image has emerged to equal the center when the interconnect is unplugged. It's as if the cones had been hibernating and needed to be played in order to loosen up. In fact, they were stored for an unknown number of years here in a dry desert climate. The rest of the imaging is also greatly improved.
    I redid the DC resistance tests to see if, magically, they had also corrected themselves; nope, same values I reported above.
    I am happy with them now; before, they were very confused sounding and nearly unlistenable for some music. They are good enough that I can now work on room placement issues; sometimes the left and right still seem excessive compared to the center.
    What do you think the next refurbishing step should be? In no particular order, I want to upgrade the SL2000s to RDO-194s, Moretite and Dynamat the drivers, and refurbish or upgrade the crossovers.
    I sure do appreciate your input on these problems.
    Regards,
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
    F1nut Posts: 52,406
    edited July 2009
    Ok Jim, I will study the pics later, no time right now.
  • jimbo1421
    edited July 2009
    OK good. Enjoy your weekend.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
    F1nut Posts: 52,406
    edited July 2009
    Nice, clear shots. :)
    The only possible issue that I can see is in the pic of the right top. The blue wire at the bottom appears to have a bad kink in it. You should check that the wire isn't broken.
    I see that this might all be mute as you state the sound has improved.
    Enjoy!
  • jimbo1421
    edited July 2009
    Enjoy!
    Thanks for looking at this, F1nut. The "bad kink" in the blue wire is due to the camera angle and is actually a gentle bend looked at endwise. I also checked the continuity while wiggling the wire as well; it's good.
    I think I will continue to give them as much playing time as I can in the next week or so, and play with room arrangements. Then reevaluate their sound and decide what is next.
    Thanks again for your time.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
    F1nut Posts: 52,406
    edited July 2009
    I would still suggest that you change the caps (resistors too) as they have reached the end of their useful life by now and that may account for the readings you're getting.
  • george daniel
    george daniel Posts: 12,096
    edited July 2009
    Enjoy!
    Eh,, the President has just issued a statement,, please use the word moot, instead of mute,for this application only. As always,, thanks in advance for your compliance with this request.Mr. President finds that it is better to be pro-active in this media release. Thank you,, BTW that looks like it would be a fun project(cap & resistor) replacement. Good lucl.
