Tube Preamp...Entry level (cheap)
starkiller
well, i guess the tube bug has bit as i am really enjoying my recently acquired jolida cd player. want to try and tube preamp now. if at all possible it needs two sets of inputs and at least 4 outputs.
i do have a Creek CD-60 cd player with rare factory remote and manual for a partial trade and probably the Acurus Preamp that the tube one would replace.
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
There are some good tube preamps available for under $500 with multiple inputs, but if you're looking for multiple sets of outputs (two or more) that seems to drive the price up a bit higher.
EDIT: Nevermind. I was thinking balanced outputs, not RCA outputs. I need to get more sleep!
/COLOR] [U][URL="http://www.polkaudio.com/forums/showcase/view.php?userid=68366"][COLOR="Blue"]My Rigs[/U][/COLOR][/URL] [COLOR="Red" Balanced Audio Technology | Revel | Dodd | Monarchy | PS Audio | MIT | Polk | Etc. -
yep, need sleep, sleep is good
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
my error...4-6 inputs, 2 outputs
Wright WLA12a,, get it used for 500.00+/-,, killer little pre,,PtP, hovelands,well built,,they pop up frequently on A'gon,,good luck.JC approves....he told me so. (F-1 nut)
I'm going to chime in here too as I'm looking at what type of tube pre i should get. Not getting one anytime soon but would like to see what people recommend, and see what kind you do get in the end and how it sounds. Keep us posted!Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Polk SR104Any clue how to use the internet? Found it in about 10 sec.
