Anybody against Powercom UPS's??
RandyWilliamson
RandyWilliamson Posts: 178
edited July 2009 in Electronics
http://3btech.net/po15unposuba.html
the price is right and so is the voltage ratings.....
anybody hear any bad stories from this brand? its one I never heard of but again the price is right and it has AVR....
my goal is to buy this first now....then go with a 2R20W Zerosurge....to offer some protection from lightning on that one off chance for the worst case scenario which as the story of my life goes....probably isn't a one off chance.
please let me know.
Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
Benq W5000
"Leaning back like a maxwell tape commercial listening to pure polk bliss"
Post edited by RandyWilliamson on
    F1nut Posts: 51,778
    edited July 2009
    Units like that are designed for computers and such, not audio.
  • AudioGenics
    AudioGenics Posts: 2,567
    edited July 2009
  • RandyWilliamson
    edited July 2009
    Price is toooooo far out my range.
    Also what I want is a battery back up....to pull through blackouts and such.
    I dont want the equipment suffering through flash power outages that happen during thunderstorms a lot sometimes.
    Right now that is priority one..becuz it is so common....then I know I know a power conditioner and surge protector is very much needed as well I agree.
    But like everything else I have to take steps due to budget...and right now they are
    1. battery backup
    2. surge protection
    3. power conditioner
    please recommend some battery backups we use in the audio world.
    Benq W5000
  • Serendipity
    Serendipity Posts: 6,975
    edited July 2009
    There are units like the Belkin PureAV UPS and APC Home Theater Power units (J15, for example) that work well with audio gear.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
    F1nut Posts: 51,778
    edited July 2009
    They may work ok for HT use, but they are nothing one would want to use with a decent 2 channel rig.
  • RandyWilliamson
    edited July 2009
    http://www.amazon.com/Cyberpower-CP1500AVRLCD-UPS-Display-8-Outlet/dp/B000FBK3QK/ref=dp_return_2?ie=UTF8&n=172282&s=electronics
    This has no complaints about humming like the Belkin AV.
    Anybody with cons on it...?
    Benq W5000
  • RandyWilliamson
    edited July 2009
    F1nut why do u say this?
    it has surge protection granted not quite as good as zerosurge...
    I can run my projector, Oppo, and pre-amp off it's backup power....and the surge only outlets for the 555.....it's got the voltage regulation so it has control over some spiking.
    Why would we need more than this....at least as a start..?
    Its got no complaints about humming which is a big deal with most UPS's.....
    Benq W5000
  • Serendipity
    edited July 2009
    So you're saying the Belkin, APC, and Panamax units are only okay for HT use?
    I thought they were made for audio/video applications.
    Correct me if I am wrong.
    F1nut Posts: 51,778
    edited July 2009
    "The Intelligent LCD Series CP1500AVRLCD UPS, designed for mid to high-end computer systems"
    Nothing about unrestricted power delivery and nothing about non-current limiting means to me that I would not want my amp(s) running thru it.
    That said, I've got that exact Cyperpower UPS for my computer and office equipment, it's great.
  • RandyWilliamson
    edited July 2009
    F1Nut so could one run the amp off the surge only line?....or better to go straight to the wall with the amp?
    The other components should be fine tho correct?
    I hear what your saying about those features but your not understanding im out of lining and in fact there's holes in my pockets. And I still want brownout protection.
    Benq W5000
  • Serendipity
    edited July 2009
    At first, I used a UPS so that my projector could cool down in the event of a power outage. If the power was interrupted there is a chance that the bulb would be damaged.
    For some reason, however, when connected to a CDP the sound quality of the player improved. There was less background noise with the UPS's filtering.
    Can someone explain this?
  • Serendipity
    edited July 2009
    Also, I don't have any amp(s) connected to a UPS. When I say audio gear, I mean CDP's, tape decks, tuners, and (in the future when I buy one) turntables.
    F1nut Posts: 51,778
    edited July 2009
    Randy,
    No.
    Yes.
    Probably.
    Can't help you with that one.
  • RandyWilliamson
    edited July 2009
    F1Nut,
    Thank you.
    thank you.
    thank you.
    And I accept donations.
    Benq W5000
  • greymatter
    greymatter Posts: 35
    edited July 2009
    clear.gifhttp://www.amazon.com/Cyberpower-CP1500AVRLCD-UPS-Display-8-Outlet/dp/B000FBK3QK/ref=dp_return_2?ie=UTF8&n=172282&s=electronics
    good to know.thanks
