Music Hall DAC 25.2 tube upgrade?
bklynNupe
bklynNupe Posts: 728
edited July 2009 in Electronics
I’m curious if anyone has replaced the stock tube in this unit or sent out for any of the modifications available? Is it worth it? Thanks
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Rtia9 /csia6 / FXi A6
Samsung LN46A650
SVS PB-12-NSD sub
Audio Research SP-9 MKIII (GNSC mods)
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Audio Aero Prima CD player
Pro-Ject debut
Post edited by bklynNupe on
  • george daniel
    george daniel Posts: 12,096
    edited July 2009
    Had a conversation well a well respected polkie last night about this very subject,,different player though,,here are his thoughts,, upgrade the stock power cord,,tubes, and (optional) the output coupling capacitors,, that should get you the biggest bang for your buck--what type of tubes does your player use?
  • bklynNupe
    edited July 2009
    Hi George, here are the specs, thanks.
    • electro-harmonix 6922 tube single-ended (rca) output
    • solid-state differential balanced output
    • ti PCM 1796 24bit/192kHz DAC
    • ti SRC 4192 asynchronous sample rate converter
    • high precision active crystal oscillator master clock
    • user selectable 96kHz or 192kHz upsampling
    • asynchronous reclocking and anti jitter control system
    • 8 x oversampling digital filter
    • 4 digital inputs: coax (s/pdif), optical, XLR (AES/EBU), or USB
    • 2 gold plated outputs; single ended (RCA), balanced (XLR)
    • headphone output with adjustable analog volume control
    • large high current oversize r-core power transformer
    • thick brushed aluminum fascia and solid chassis
    • 110v/220v voltage selectable transformer
    • detachable power cord
    thd+n: <0.04% tube out (1KHz)
    <0.0015% balanced out (1KHz)
    output level: 2.0V
    frequency response: 2Hz~20KHz +/-0.2dB
    snr: >110dB
    power dissipation: <30W
    dynamic range: > 120dB (24 bit)
    > 96dB (16bit)
    crosstalk: <-110dB
    operating temperature: 0 ~ 40
    headphone output level: 4V max
    headphone output resistance: 0.3 ohm
    power supply: AC115V/60Hz - 230V/50Hz
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Samsung LN46A650
    SVS PB-12-NSD sub
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Pro-Ject debut
  • bklynNupe
    edited July 2009
    I've been reading about the tube upgrades, but I really don't know too much about what tube would be the best and what vendors I should consider?
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Samsung LN46A650
    SVS PB-12-NSD sub
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Pro-Ject debut
  • george daniel
    edited July 2009
    Just my .02 worth,,buy NOS,,, Brent Jesse,,Jim McShane,, or any reputable dealer,, you'll pay more for REAL NOS,,but your ears will tell you why you spent the money.Tube rolling can be fun,, first,what kinda sound are you looking for,,up front,laid back,,revealing,, you need to answer those questions first. Start with an entry level PC,, Signal Cable,PS Audio, are good places to start,, look here in the FM,,buy a used power cable,,if you don't like it,you can always sell it here,,ask other owners for advice based upon their experience,, members on this forum have alot of experience that will steer you clear of "pitfalls",if you listen to them.Good luck,,and most of all have fun,,BTW,, you're heading down the right path---SOURCE-- have fun. :)
  • bklynNupe
    edited July 2009
    Good advice George.
    I've been curious about the benefits of swapping out power cords, I guess I've been trying to prioritizing everything in my sound chain according to benefit and cost. In addition I have to process all of the info in my noggin.
    So far as the tube preference, I’m really not sure.
    A while back I purchased a Bellari VP129 Tube Phono Peamp from Audiogon. The seller included 4 extra tubes. I didn’t notice much of a difference between them. Except 1 RCA 6201. I really liked this one because it sounded warmer and smoother than the rest.
    For what it is worth, I hope this is an Apples to Apples comparison.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Samsung LN46A650
    SVS PB-12-NSD sub
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Pro-Ject debut
  • bklynNupe
    edited July 2009
    So any suggestions on tube replacements? I don't have a clue so far as what to consider. Thanks.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Samsung LN46A650
    SVS PB-12-NSD sub
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Pro-Ject debut
  • miner
    miner Posts: 1,305
    edited July 2009
    I think this months Stereophile has done a review on the DAC.
  • jabrax
    jabrax Posts: 315
    edited July 2009
    Nupe - several sites have mentioned the JJ6922 as the upgrade tube of choice for this dac. Here is an example from Audiogon thread.
    http://forum.audiogon.com/cgi-bin/fr.pl?ddgtl&1240017810&read&keyw&zzmusic+hall+25+2
    Yes, I am still waiting to snag one of these..... They just are not coming up for resale used... I consider that a good sign :)
    TV...............Hitachi 42hdS52a plasma (sexy one with the swival)
    Pre/Processor - Emotiva MMC
    Seven Ch AMP - Emotiva LPA
    Fronts - Tyler Acoustics 7U's
    Center - Polk LSIC
    Sub - DSWPRO600
    DAC - Music Hall 25.3CD - Marantz cc4001
    Blue Ray - PS3
    Speaker cables - Audioquest cv4 dbs
    Interconnects - MIT AVT1's
    Power Filter....Monster HTS 3500 MKII
  • debussyj
    debussyj Posts: 198
    edited July 2009
    I was considering picking up this DAC myself. I have an Audible Illusions Modulus 3B Preamp and it uses the same tubes (6922's). I've got all kinds in my personal stash. My favorites being Amperex Gold Pin, Siemens, Tungsram, Sovteks, Mullards. I just swap out the tubes depending on my mood and the sound I'm looking for. My favorites are the Amperex and Siemens. The Mullards sound very sweet, but my preamp runs hot and kills tubes easily and they just don't stand up very well. DJ
  • bklynNupe
    edited July 2009
    So I just ordered the NOS Mullard E88cc/01 to replace the Electro-harmonix 6922 stock tube in my Music Hall DAC 25.2.
    I purchased from Brent Jessee at George's recommendation, I actually spoke to Brent via e-mail and over the phone.
    According to Brent, this tube is from the '60's and will make a huge improvement in my sound, so much that you will not need to do other modification to my DAC. According to Brent, these are 10,000 hour rated so will outlast up to 4 pairs of Russian tubes!
    Anyone own this particular tube? Any thoughts?
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Samsung LN46A650
    SVS PB-12-NSD sub
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Pro-Ject debut
  • bklynNupe
    edited July 2009
    jabrax wrote: »
    Hey Jabrax, I did come across this on Audiogon discussion in an earlier search. From the postings, I got the sense that the modification was recommended with this particular tube. I asked Brent Jessee’s opinion about the modification, he felt the Mullard tube would be enough. Certainly, a highly rated tube is cheaper than a modification. So I figured I’d give the Mullard a try. I may still try the modification, depending on my findings. As is, I like my Music Hall, but you know how it goes, .. always looking for a notch better.:D Thanks.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Samsung LN46A650
    SVS PB-12-NSD sub
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Pro-Ject debut
    F1nut Posts: 51,802
    edited July 2009
    more cable nonsense
    Hey tagger, you're a chicken **** coward and a complete moron. This thread is about tubes.
    F1nut Posts: 51,802
    edited July 2009
    bklynNupe wrote: »
    Here's another highly recommended tube dealer.
    https://www.tubeworld.com/index_high.htm
  • madmax
    madmax Posts: 12,434
    edited July 2009
    I came here looking for more cable nonsense but all I see is jibberish about tubes... Damn. The amperex bugle boy 6922 tube did awsome things to my preamp. I'm thinking about trying one of those in the music hall, if I can find one of the tubes.
    madmax
    Vinyl, the final frontier...
  • debussyj
    debussyj Posts: 198
    edited July 2009
    Tubeworld is great. I've bought several tubes from Brendan. He's a good guy and very helpful. DJ
