Mac Pro tools hook up questions?
rallyshark
I guess my main question is: Would it be OK to hook up the out put from a mac pro tools box to one of the inputs of my receiver? My roommate wants to listen to it on some good speakers for some editing of some tracks for her band. I know it has balanced and unbalanced outputs, but I'm not sure which "box" it is. I'm assuming I would need to use the unbalanced with RCAs, right? I know very little about this, and don't want to screw up my equipment, but if it's perfectly safe then I'm glad to help. I also think it would be fun. Do you guys have any advice on this one? I'm trying to find out exactly which pro tools set up her bandmate has, but right now I don't know. Please let me know if you have any tips/advice/warnings about this one
Thanks again!
Sony 40" LCD
Sony DVPCX995V
Sony PS3(games/media server)
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car?
Sony DVPCX995V
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
Post edited by rallyshark on
Yes, it's ok to hook up to a stereo. Just don't go plugging the balanced outs into a unbalanced RCA in without knowing what your doing though. Just because you can get an adapter from one type of plug to another doesn't mean it's the right way to do it necessarily. I've always suspected that many people would plug a pair of headphones into an AC outlet if they had an adapter handy to do it with!! :eek:
Probably the easiest way is to do it SPDIF. Most all of the ProTools have that as an output option and if you have a SPDIF into your receiver, then one short cable and your good to go!
CoolJazzA so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping." -
I guess I haven't woke up yet, but what do you mean by SPDIF?Sony 40" LCD
Sony DVPCX995V
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car? -
I would do it by the RCA output jacks if it has them....SPDIF is a digital connection I think, like coax (1 RCA wire)
Audio Physic Scorpio II
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP -
Thanks guys! I was able to make it work and the good'ol 11Ts performed as needed:)Sony 40" LCD
Sony DVPCX995V
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
