Good quality speaker wire at affordable price?
digitalvideo
I am looking for very good quality speaker wire for my 7.1 surround speaker system that doesnt bust my bank. Is there a speaker wire company out there that is sort of like what Bluejeans cable is for HDMI where they put out a very good cable/wire at a good price?
How important is it to have high quality speaker wire and can you notice a big difference in how your system performs between a $50 wires and $300 dollar wires?
Post edited by digitalvideo on
Yes there is and it all depends on how good your equipment is.
What equipent do you have ?
A lot of people will recommend Signal Cable, I just tried one of their Analog 2 ICs for my TT and I am very impressed.
A friend brought his Pro-Ject II SE tube phono stage over yeaterday and we sample 4 cables between Phono Stage and Pre-Amp. There were definately differences.
Now, if take a HTiB I suspect you could put expensive excellent cables on the system and tell no difference.
I equate it to taking a economy car and putting expensive tires on it and running premium gas, you would not be able to tell a difference.
Take a sports car and you can tell the diffence in cheap, good and best tires as well as low, meduim and high grade gas.Speakers: SDA-1C (most all the goodies)
Your ears. Your budget. Start with something decent and don't overpay for Monster.
I'd go back to BJC for speaker wire. I use it all around the house. You'll find a lot of Signal Cable fans here. I've never used SC speaker wire, but I can recommend the interconnects (Analog II) and power cables (Magic Power).Main Rig
Pioneer Elite SC-05, Rotel RMB-1075
RT800i, CS400i, RT35i, FXi50, Klipsch RSW-12
Pioneer Elite DV F-07, PS3, Wii
Monster HTS 3500 MKII
SC Analog 2, BJC Speaker Wire
Samsung HL61A650
2nd Rig
Pioneer Elite VSX-56txi, Pioneer Elite DV-47a
Cambridge Soundworks, MC150 (Center), MC100 x 4, Mirage LF-150
Office
Adcom GTP-400, Adcom GFA-535II, (need a quality CDP), RT55i -
Are you going to be running any of the wire in-wall?2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
My home theater surround sound setup is in full HDMI and is used primarly for tv/sports movies/bluray/dvd.
My home theater 7.1 surround system is:
Pioneer Elite Kuro Pro-111fd plasma
Pioneer Elite SC 05 reciever
Oppo BDP-83fd
Sunfire Cinema Grand Signature 400 7 channel amp
Center speaker - Polk CSi A6
Front tower floor speakers L/R - Polk RTI A9
Side speakers - Polk FXI A6
Rear Speakers - Polk FXI A6
Sub - SVS PB12 Ultra -
Also what are your views and opinions on the Bluejeans BJC 5000ue or Twelve White speaker cable? How do they compare to Signal Cable?
dragon1952 wrote: »Are you going to be running any of the wire in-wall?
Nope, I have the wire on the ground right up against the wall around the room underneath and behind furniture with matching wall wire covers over it. The wire covers are the same color as the paint on the wall so it looks good and is hard to notice, I had a friend who does interior decorating do that for me. -
digitalvideo wrote: »My home theater surround sound setup is in full HDMI and is used primarly for tv/sports movies/bluray/dvd.
Oppo BDP-83fd
Blue Jeans Cables should do you just fineSpeakers: SDA-1C (most all the goodies)
The Belden is an excellent cable. I use it for my rears and am very happy with it.
www.monoprice.comdigitalvideo wrote: »I am looking for very good quality speaker wire for my 7.1 surround speaker system that doesnt bust my bank. Is there a speaker wire company out there that is sort of like what Bluejeans cable is for HDMI where they put out a very good cable/wire at a good price?
one of the best priced for a good quality stuff, has got very good CS i have dealt with them couple of times and returned some stuff when i had ordered wrongly you can try them.
No Affiliations. -
I got some banana plugs from monoprice for my speaker-wire and noticed that when I insert the plug into the jacks on my amp and the jacks on my speakers, that even after I tighten the plastic housings all the way down I can still pull the banana plug out of the jack. Same thing happens on another set of speaker wire I have equipped with banana plugs. Is this normal? Shouldn't tightening the plastic housing on the jacks keep the plugs tight and unable to be pulled out?
C'mon guys, somebody has to know if banana plugs are supposed to be able to be tightened down onto the jack so that they can not be pulled out. I didn't want to start a new thread just to ask so sorry for the hijack. But I'm able to remove the plug from the jack despite tightening the plastic housing all the way down. Is that normal? Someone, please?
Freak When C wrote: »C'mon guys, somebody has to know if banana plugs are supposed to be able to be tightened down onto the jack so that they can not be pulled out. I didn't want to start a new thread just to ask so sorry for the hijack. But I'm able to remove the plug from the jack despite tightening the plastic housing all the way down. Is that normal? Someone, please?
Yes this is normal. Banana plugs are meant to be inserted and removed. They are never permanently installed. Now, stop thred hijacking.:eek:
Toshiba 62HMX85
Panasonic DMP-BD60
Xbox 360 with HD-DVD
Pioneer VSX-9130-TXH-K
Polk Audio CSiA6
Polk Audio RTi10's
Polk Audio RTi4's
Polk Audio RTi6's
Polk Audio PSW505 -
ive bought all my hdmi and speaker wire cables from monoprice.com. there are great, and a 4' cat 3a hdmi cable for 3 bucks is a killer deal!!!
I realize they're not meant to be "permanently installed" :rolleyes: Of course they would need to be able to be inserted and removed. How else would you connect and disconnect speakers, otherwise? That is NOT what I'm asking.
After I insert the banana plug into the receptacle (the jacks on the amp and rear of the speakers) and I then tighten down the plastic housing, the plug can still be easily removed WITHOUT loosening the plastic housing. In other words, tightening the plastic piece on the amp jacks and speaker jacks that accept banana plugs seems to do nothing. Is that normal? -
You are absolutely confused, they are not meant to act in the manner what you describe, Banana plugs whether you tighten the plastic or not will plug in and come out easily, the whole purpose is to have a snug fit and be able to remove when required, not the way you think, kind of lock mechanism.
jacob.simpson wrote: »You are absolutely confused.
I am not confused at all. I thought perhaps they're actually designed to work this way, but was not sure. I'm merely asking for verification that they're supposed to be able to be disconnected with the plastic housing tightened down, or if they're supposed to lock the way my interconnect cables do.
I just was asking if it's normal, that's all. Thanks.
Your banana plugs are behaving normally. Tightening or loosening the plastic nut on the binding post doesn't make a difference.
They do make locking banana plugs as well, if you're looking for a more secure connection. The GLS locking bananas are high quality, and don't break the bank.
http://cgi.ebay.com/28-Locking-Banana-Speaker-Cable-Plugs-GLS-Audio-P-BL28_W0QQitemZ350154366730QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5186d39f0a&_trksid=p4634.c0.m14.l1262&_trkparms=|293%3A1|294%3A30The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Nice to know my bananas aint giving me the slip. I noticed one of my plugs was kind of not inserted all the way which is how I discovered they weren't locked in. But thanks for clearing up my "confusion". I just wasn't sure they were supposed to work that way.
Those locking ones look nice. I just might snag em. I really like how they work. "As you screw the shell on, it presses against the locking bar and spreads the internal spike into the tip" Awesome! Thanks Curt.
Why didn't you just google "Banana plugs"? That would have explained it all in about 30 seconds.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Because I'm lazy?
I did Google "banana plugs slips out of jack" and didn't really find what I needed. I always try to be too precise with Google, for some reason. Much easier to come and ask the experts here on CP
(but I did try Google first). -
The fact that the speaker terminals screw in and out has nothing to do with tightening the connection unless you are using bare wire or spades. For banana connectors you should tighten the jack all the way down first, and then insert the banana. The bananas just push in and pull out. They are held secure by the springs clips on the banana connector, or by compression of the connector. Some fit tighter than others. If they fit too loose, you can sometimes use a pointed object and pry the spring clips apart a little. Or in the case of BFA types, you can insert something close to the inner diameter of the connector and try and pry it open a bit.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
One word - Monoprice. You can usually catch the wire on sale if it is the daily deal for a very good price. They have good prices on banana plugs as well.
i have monster cable everything, speaker, hdmi, digital coax, sub cable etc. but i get them like 75% through work
setup
Panasonic 46pz85
Polk RTi A9's
Polk CSi A6
FXi A6's
Energy s12.3 sub
Denon 3808ci
Pioneer elite dv-79
Monster 1850
Denon dp500m w/ grado green
PS3,XBOX 360, NES -
OK, don't laugh (or yell!) I have used 12 gauge landscape lighting wire. Yep, the black stuff you find at HD or Lowe's. It is a LOT cheaper than similar gauge speaker wire, and if it will hold up outside or buried, it will be OK in my HT.My 7.4.4 DIY 4k Home Theater:
Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
Polk LSiM 702s x 4 on the Ceiling Atmos speakers
Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
Denon X3700H Emotiva XPA11 Gen 3
XBox One X 4k & BD and streaming
Panasonic UB-420 4k player
HD-A35 HD DVD
Oppo BD-103D for hirez audio
Technics SL-D2 TT, Grado Gold Cartridge
JVC DLA-RS2100/NZ7 projector
Silver Ticket 135" microperf AT screen
Berkline 090 electric recliners with Aura Bass Shakers -
I use coat hangers, they work well and are cheap.
For every job, there's a tool.Main Rig
Samsung HL61A650
2nd Rig
Office
