Quick HT question
madmax
madmax Posts: 12,434
Is it OK to put the sub in the back of a home theater room? A friend was asking and truthfully I am more of a music guy and don't know how much it matters.
madmax
Vinyl, the final frontier...
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2003
    Mad - Yes, that would be fine. Usually placement occurs where the sub sounds best. It is common for front placement, but there is nothing wrong with moving it to what best suits the individual.
    You will get different sound from certain placement, as you know.
  • Frank Z
    Frank Z Posts: 5,860
    edited August 2003
    Sure!! The bass frequencies are non-directional so location can be just about anywhere. A simple means of finding the right spot for the sub is place it in your favorite seat position and then stand in different parts of the room. once you find the spot where the sound from the sub sounds the best, you simply place the sub where you are standing. Not very scientific, but it works!
