Screws for a B&K ST-202 plus
Big Dawg
Big Dawg Posts: 2,005
edited December 2009 in Wanted (WTB) Classifieds
I recently acquired several B&K pieces, among them an ST-202 plus 200 wpc amplifier (the older, black with gold handles style). Unfortunately, it arrived without screws to close the case:mad:. Does anyone have any suggestions as to where I could buy some (or, better still, have an old B&K amp I can use for parts)?
Thanks!
Post edited by Big Dawg on
  • snow
    snow Posts: 4,358
    edited June 2009
    Big Dawg wrote: »
    Thanks!
    I would simply look through my assortment of old screws that I have taken off old components until I found one that fit properly then if I didnt have enough of that style to complete it simply go to my local hardware store or fastener company and purchase as many as I needed, most likely for a buck or two at most your good to go.
    REGARDS SNOW
  • Big Dawg
    edited June 2009
    I've been to Lowes and Home Depot, neither can match it. I've called B&K, but they can't/won't help me. I must confess to some disappointment with B&K, as one of the reasons (in addition to the sound and build quality of their stuff) I chose to pursue their vintage equipment was all of the good things I've read about the support they provide their older gear (much like Polk, on all counts, one of the reasons I've become a fan here too).
    If anyone has a few sets of old screws lying around, I am open to buying them, including all costs, but am especially hoping to find actual B&K screws, as the probability of a good fit would seem to be much higher.
    Snow, I will try some more of the ones I have lying around, but I have more computer case screws than I do those from audio gear, and the ones I've tried so far don't seem to work. Thanks for your suggestion, though!
  • snow
    snow Posts: 4,358
    edited June 2009
    Big Dawg wrote: »
    Yes Home Depot or lowes most likely wouldndt have a great assortment of sheetmetal screws similar to what you need, you would have to go to a fastener company or a Hardware store that carries a huge variety of this type of screw.
    Do you have one screw to compare that will work so you can get more? Sometimes you can get one from the bottom of the amp or another place on the amp then take it and match the diameter and thread pattern. If I knew what those specs were I could either send you however many you need or find a place online that would sell you them.
    REGARDS SNOW
  • snow
    snow Posts: 4,358
    edited June 2009
    I asked about the screws needed on another forum and a fellow that has your identical amp has said he will take one of his screws out and find out what the diameter, pitch, length is and respond back with the specs so hang tight, once we find out what those are we can find you some online if there isnt a place local to you.
    REGARDS SNOW
  • Big Dawg
    edited June 2009
    Snow,
    That's awesome, thanks!
    Dawg
  • snow
    snow Posts: 4,358
    edited June 2009
    Ok Dawg this is the reply I received hope this helps.
    Sears Hardware stores have them.
    #6 diameter, half inch sheet metal screws. They only had stainless steel ones but the guy there said other Sears stores might have them black painted.
    I was going to buy one to take home to make sure but the guy said "You only want on? Just take it". Fit perfect. Would have been 15 cents a piece. They are found in the screw drawers.
    Ok...forgot, just to make sure mine is older type B&K, with the plain black face and the gold lettering and handles.
    REGARDS SNOW
  • Big Dawg
    edited July 2009
    Snow,
    I'll head over to Sears and check it out. My only concern is matching the threads - hopefully it will fit!
    Thanks very much.
    Dawg
  • reeferdube
    reeferdube Posts: 1
    been looking for one of those for a while, care to part with yours if you haven't already?
  • RyanJoz
    RyanJoz Posts: 116
    Fastenal will have them. Most of them are #6's and Fastenal even has them in black with the allen drive. Recently had the same thing happen to me with an Adcom amp.
    Ryan Jozwiak
    "Because music was meant to be felt and heard"
    polkaudio RTiA9
    polkaudio RT35i
    polkaudio PSW 404
    HK 3370
    HK FL8380
    HK DVD 22
    Adcom GFA 5500
    Samsung 40" LCD 120 Hz
