need some opinions
i'm about to upgrade my LCR from my current cheap Philips FB975 setup to im thinking monitor 50's with a cs2. would like to get some opinions the way im thinking about placing them. also, i know i shouldn't even really ask this, because the difference will probably be night and day, but how much difference do you think the sound of the m50's/cs2 would be over the current philips i have? current system setup is listed in my sig. thanks.
Current Entertainment Setup
TV: 42" LG 42LG30 LCD, AVR: Onkyo TX-SR604, BDP: Panasonic DMP-BD60
Fronts: Polk Monitor 60, Center: Polk CS1, Surrounds: Polk Monitor 40, Sub: Polk PSW10
Gaming: Xbox 360 Elite, Live Gamertag: ToXSiC
Post edited by ToXSiC on
That looks reasonable....you may have to play with the sub position a bit, that might be a good place for it or not the best! Perhaps I'd move the LS closer to the couch if possible.
And yeah! You'll notice a difference in the surround sound over a Philips. What are you going to use to POWER those speakers because that's ALSO a factor!
And the sub is?
i guess my sig isn't showing up for some reason? i have an Onkyo TX-SR604 and Polk PSW10 sub.
hah! after i posted this initial reply my sig decided to come out of hiding.Current Entertainment Setup
Gaming: Xbox 360 Elite, Live Gamertag: ToXSiC -
An Onkyo 604 will do those speakers fine! And the PSW10, although an entry level sub, will give the M50s the bottom end they don't have in what seems to be a smallish room. That's really the optimal room size for the PSW10!
You'll be surprised how good that speaker set will sound with the 604!
i have absolutely no problem with this sub, i had a small PIO sub before this one and there is a night and day difference between the 2, unfortunately, the current placement is about the only place it can go due to the other furniture in the room.Current Entertainment Setup
Welcome to Club Polk ToXSIC
hearingimpared wrote: »Welcome to Club Polk ToXSIC
thanks!Current Entertainment Setup
I had a sony home theater in a box and it is NIGHT and DAY difference with the cs2 and the monitor 50s.HOME AUDIO:
Electronics:
HK 354
Front Power: CARVER TFM-35
Center Power: Audiosource Amp One
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
psw 125 + psw 505 = BOOM
CAR AUDIO
Infinity 6032CF's all around -
cool, i'm looking forward to getting them, just tryin to find a really good deal on them, im on a pretty tight budget and may have to piece them together, but im also pretty patient, so im in no big hurry.Current Entertainment Setup
Well if you're ever hungry and wanting to add another sub....lol Ive still got one for sale.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Newegg often has sales or coupon codes on Polk speakers. Check www.xpbargains.com or www.slickdeals.net from time to time and do a search for Polk and you may find a promo code or a sale alert. I saved $60 on the pair of Monitor 60's I recently bought by using promo codes at Newegg. The code was good for $30 off one speaker and was only good once per account. So I made a second account and it worked like a charm.
Welcome to Club Polk Osarion!
Welcome to the Club!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
That looks a lot like my dorm room setup last year, except I had an RA knocking on my door every ten minutes because I had my dwspro400 right next to the door, ha. Imagine if I had my svs then...Bulls make money.
Bears make money.
Pigs get slaughtered.
You, my friend, are the bacon. -
hearingimpared wrote: »Welcome to Club Polk Osarion!
Thanks! Glad to be here!! -
Welcome... 12x12 right ? what is the ceiling height ?
I'd put the sub in the top right corner.
joseph.v.chen wrote: »Welcome... 12x12 right ? what is the ceiling height ?
7.5' im thinkingCurrent Entertainment Setup
right now, there is a small dresser there, that i don't really need, and it's gone as soon as i get all my new stuff. the only reason i didn't include the dresser in the drawing is because it won't be there long and the drawing represents the actual layout im gonna go with when i get my stuff. so, i'll probably try it in the right front corner of the room when i get everything situated and see how much better it sounds than it does now.Current Entertainment Setup
Subs love corners --- especially if they are small or underpowered. -
i've been moving stuff around and cleaning up in general trying to get ready to do all of this. i ended up buying monitor 60's instead of 50's from newegg since they had them for 129 per speaker, ended up paying 260 shipped for the pair of M60's. still gotta get me a center though, hopefully find one in the next couple of weeks. i actually plan on moving the sub to the front right corner of the room, i gotta get a longer sub cable though because the one i have is only like 3'.Current Entertainment Setup
The M60s are a nice compromise...a bit more ooomph than the 50s and yet not that much larger in size. I think you'll like those...they compare quite favorably in that price range with most major manufacturers. I find them 'superior' to the Klipsch Synergy line for example...but then again I can't stand most HORNS!
cnh
a quick question, i know most of you would recommend the cs2, but would it not make more sense to match the cs1 with the 60's and run the same size speakers all the way across?Current Entertainment Setup
Definitely go with the CS2 it's the best in the series and will match up with the M60s fine and give you more sound. Remember that center is going to carry the bulk of the surrround track info! I have M70s and the CS2 but I know a lot of other guys that run CS2s with M50s and love it!
I agree with cnh, the cs2 will give better focus for movies dialogue. The larger the center the better and keep in mind you are staying in the same series of center anyway.Definitely go with the CS2 it's the best in the series and will match up with the M60s fine and give you more sound. Remember that center is going to carry the bulk of the surrround track info! I have M70s and the CS2 but I know a lot of other guys that run CS2s with M50s and love it! cnhDARE TO SOAR:
I have the CS2 paired with the M60's and M40's in the back and everything sounds great.
Makes sense (good match)!I have the CS2 paired with the M60's and M40's in the back and everything sounds great.DARE TO SOAR:
this is probably gonna be the way i go as well, i got my M60's today, lookin around for a good deal on a new or used cs2 now, and when my budget allows, ill grab the M40's for surrounds.Current Entertainment Setup
