need some opinions
ToXSiC
ToXSiC Posts: 31
edited June 2009 in Speakers
i'm about to upgrade my LCR from my current cheap Philips FB975 setup to im thinking monitor 50's with a cs2. would like to get some opinions the way im thinking about placing them. also, i know i shouldn't even really ask this, because the difference will probably be night and day, but how much difference do you think the sound of the m50's/cs2 would be over the current philips i have? current system setup is listed in my sig. thanks.
Current Entertainment Setup
TV: 42" LG 42LG30 LCD, AVR: Onkyo TX-SR604, BDP: Panasonic DMP-BD60
Fronts: Polk Monitor 60, Center: Polk CS1, Surrounds: Polk Monitor 40, Sub: Polk PSW10
Gaming: Xbox 360 Elite, Live Gamertag: ToXSiC
Post edited by ToXSiC on
    edited June 2009
    That looks reasonable....you may have to play with the sub position a bit, that might be a good place for it or not the best! Perhaps I'd move the LS closer to the couch if possible.
    And yeah! You'll notice a difference in the surround sound over a Philips. What are you going to use to POWER those speakers because that's ALSO a factor!
    And the sub is?
    cnh
  • ToXSiC
    ToXSiC Posts: 31
    edited June 2009
    i guess my sig isn't showing up for some reason? i have an Onkyo TX-SR604 and Polk PSW10 sub.
    hah! after i posted this initial reply my sig decided to come out of hiding.
    edited June 2009
    ToXSiC wrote: »
    An Onkyo 604 will do those speakers fine! And the PSW10, although an entry level sub, will give the M50s the bottom end they don't have in what seems to be a smallish room. That's really the optimal room size for the PSW10!
    You'll be surprised how good that speaker set will sound with the 604!
    cnh
  • ToXSiC
    ToXSiC Posts: 31
    edited June 2009
    i have absolutely no problem with this sub, i had a small PIO sub before this one and there is a night and day difference between the 2, unfortunately, the current placement is about the only place it can go due to the other furniture in the room.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2009
    Welcome to Club Polk ToXSIC
  • ToXSiC
    ToXSiC Posts: 31
    edited June 2009
    thanks!
  • royalty
    royalty Posts: 246
    edited June 2009
    I had a sony home theater in a box and it is NIGHT and DAY difference with the cs2 and the monitor 50s.
    HOME AUDIO:
    Electronics:
    HK 354
    Front Power: CARVER TFM-35
    Center Power: Audiosource Amp One
    Speakers:
    Center: CSi5
    Fronts: rti10s
    Rears: monitor 50s
    psw 125 + psw 505 = BOOM
    CAR AUDIO
    Infinity 6032CF's all around
  • ToXSiC
    ToXSiC Posts: 31
    edited June 2009
    royalty wrote: »
    cool, i'm looking forward to getting them, just tryin to find a really good deal on them, im on a pretty tight budget and may have to piece them together, but im also pretty patient, so im in no big hurry.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited June 2009
    Well if you're ever hungry and wanting to add another sub....lol Ive still got one for sale.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Osarion
    Osarion Posts: 188
    edited June 2009
    Newegg often has sales or coupon codes on Polk speakers. Check www.xpbargains.com or www.slickdeals.net from time to time and do a search for Polk and you may find a promo code or a sale alert. I saved $60 on the pair of Monitor 60's I recently bought by using promo codes at Newegg. The code was good for $30 off one speaker and was only good once per account. So I made a second account and it worked like a charm.
  • hearingimpared
    edited June 2009
    Welcome to Club Polk Osarion!
  • danz1906
    danz1906 Posts: 5,144
    edited June 2009
    Welcome to the Club!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • mdk5068
    mdk5068 Posts: 204
    edited June 2009
    That looks a lot like my dorm room setup last year, except I had an RA knocking on my door every ten minutes because I had my dwspro400 right next to the door, ha. Imagine if I had my svs then...
    Bulls make money.
    Bears make money.
    Pigs get slaughtered.
    You, my friend, are the bacon.
  • Osarion
    Osarion Posts: 188
    edited June 2009
    Thanks! Glad to be here!!
  • AudioGenics
    AudioGenics Posts: 2,567
    edited June 2009
    Welcome... 12x12 right ? what is the ceiling height ?
  • ky_polkie
    ky_polkie Posts: 48
    edited June 2009
    I'd put the sub in the top right corner.
  • ToXSiC
    ToXSiC Posts: 31
    edited June 2009
    7.5' im thinking
  • ToXSiC
    ToXSiC Posts: 31
    edited June 2009
    ky_polkie wrote: »
    right now, there is a small dresser there, that i don't really need, and it's gone as soon as i get all my new stuff. the only reason i didn't include the dresser in the drawing is because it won't be there long and the drawing represents the actual layout im gonna go with when i get my stuff. so, i'll probably try it in the right front corner of the room when i get everything situated and see how much better it sounds than it does now.
  • ky_polkie
    ky_polkie Posts: 48
    edited June 2009
    ToXSiC wrote: »
    Subs love corners --- especially if they are small or underpowered.
  • ToXSiC
    ToXSiC Posts: 31
    edited June 2009
    ky_polkie wrote: »
    i've been moving stuff around and cleaning up in general trying to get ready to do all of this. i ended up buying monitor 60's instead of 50's from newegg since they had them for 129 per speaker, ended up paying 260 shipped for the pair of M60's. still gotta get me a center though, hopefully find one in the next couple of weeks. i actually plan on moving the sub to the front right corner of the room, i gotta get a longer sub cable though because the one i have is only like 3'.
    edited June 2009
    The M60s are a nice compromise...a bit more ooomph than the 50s and yet not that much larger in size. I think you'll like those...they compare quite favorably in that price range with most major manufacturers. I find them 'superior' to the Klipsch Synergy line for example...but then again I can't stand most HORNS!
    cnh
  • ToXSiC
    ToXSiC Posts: 31
    edited June 2009
    cnh wrote: »
    cnh
    a quick question, i know most of you would recommend the cs2, but would it not make more sense to match the cs1 with the 60's and run the same size speakers all the way across?
    edited June 2009
    Definitely go with the CS2 it's the best in the series and will match up with the M60s fine and give you more sound. Remember that center is going to carry the bulk of the surrround track info! I have M70s and the CS2 but I know a lot of other guys that run CS2s with M50s and love it!
    cnh
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited June 2009
    cnh wrote: »
    Definitely go with the CS2 it's the best in the series and will match up with the M60s fine and give you more sound. Remember that center is going to carry the bulk of the surrround track info! I have M70s and the CS2 but I know a lot of other guys that run CS2s with M50s and love it! cnh
    I agree with cnh, the cs2 will give better focus for movies dialogue. The larger the center the better and keep in mind you are staying in the same series of center anyway.
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • Osarion
    Osarion Posts: 188
    edited June 2009
    I have the CS2 paired with the M60's and M40's in the back and everything sounds great.
  • TECHNOKID
    edited June 2009
    Osarion wrote: »
    Makes sense (good match)!
    DARE TO SOAR:
  • ToXSiC
    ToXSiC Posts: 31
    edited June 2009
    Osarion wrote: »
    this is probably gonna be the way i go as well, i got my M60's today, lookin around for a good deal on a new or used cs2 now, and when my budget allows, ill grab the M40's for surrounds.
