new interesting interconnects
marvda1
marvda1 Posts: 4,958
first off i am not affiliated with this seller, just an interesting read and since they only cost $88 for up to a meter pair thought i might give them a try.
what do you think?
http://home.comcast.net/~jafix/interconnect.html
marvin
Puritan PSM156
Post edited by marvda1 on
  • danz1906
    danz1906 Posts: 5,144
    edited June 2009
    Seems like they may sound good
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • jimmydep
    jimmydep Posts: 1,305
    edited June 2009
    They look like intersting cables.
    Did you read the description....."This very same cable is used to transmit the final fuzing and target parameters to the nuclear bomb warheads on both the B-1B Lancer and the B-52 moments before weapon release."
    I bet they have a great LOW end.... KABOOM!!!
  • marvda1
    edited June 2009
    here's some more pricing info.
    "Pricing for either the KV01 or KV02 is $88/pair for lengths of 1m or less. Each additional meter or fraction thereof is an additional $20. Price includes USPS Priority Mail shipping and a lifetime guarantee.
    Each set is made to order; lead time right now is around 5 days. Thank you for your interest, and please don't hesitate to email with any other questions that you may have."
    Puritan PSM156
  • thsmith
    thsmith Posts: 6,082
    edited June 2009
    Marvin, if you decide to get these please share your thoughts.
  • marvda1
    edited June 2009
    just got this back explaining the difference in the two models.
    Hi Marvin,
    The KV01 interconnect has the shield ground routed separate from the signal ground. If you have an amplifier that can take advantage of this feature, the noise floor is a little lower than the KV02 model that has the shield ground tied to the signal ground at one end of the cable. If your amplifier has a separate screw-down ground terminal (usually marked for phono) the KV01 is a better choice. If your amp simply has RCA inputs/outputs with no separate ground lug, the KV02 is the way to go.
    Best Regards,
    Jeremy
    Puritan PSM156
