new interesting interconnects
marvda1
first off i am not affiliated with this seller, just an interesting read and since they only cost $88 for up to a meter pair thought i might give them a try.
what do you think?
http://home.comcast.net/~jafix/interconnect.html
marvin
what do you think?
marvin
Puritan PSM156
Puritan PSM156
Post edited by marvda1 on
Seems like they may sound goodLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
They look like intersting cables.
Did you read the description....."This very same cable is used to transmit the final fuzing and target parameters to the nuclear bomb warheads on both the B-1B Lancer and the B-52 moments before weapon release."
I bet they have a great LOW end.... KABOOM!!! -
here's some more pricing info.
"Pricing for either the KV01 or KV02 is $88/pair for lengths of 1m or less. Each additional meter or fraction thereof is an additional $20. Price includes USPS Priority Mail shipping and a lifetime guarantee.
Each set is made to order; lead time right now is around 5 days. Thank you for your interest, and please don't hesitate to email with any other questions that you may have."Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Marvin, if you decide to get these please share your thoughts.Speakers: SDA-1C (most all the goodies)
just got this back explaining the difference in the two models.
Hi Marvin,
The KV01 interconnect has the shield ground routed separate from the signal ground. If you have an amplifier that can take advantage of this feature, the noise floor is a little lower than the KV02 model that has the shield ground tied to the signal ground at one end of the cable. If your amplifier has a separate screw-down ground terminal (usually marked for phono) the KV01 is a better choice. If your amp simply has RCA inputs/outputs with no separate ground lug, the KV02 is the way to go.
Best Regards,
JeremyAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156
