SDA Center Channel... let the fun begin!
Looks good John.
Thanks Larry! Looks is one thing but sound is another. As I said, in an audio environment it sounds pretty good, but as a center for movies, the dynamics are terrible at this point. There is an audio repair shop that specializes in crossover setup here in town and it will be headed there in the morning.TOOLFORLIFEFAN wrote: »Looks good John.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Nice work John!Speakers: SDA-1C (most all the goodies)
When I finish the cabinet off, I will be sealing one of the two ports on the back as it sounds much better that way, and I think once the mids are set at the proper crossover points everything will be fine.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Careful John,
You might start getting 'orders' from all of us who run SDA/SRS speakers!
That's a nice looking center. God you guys MOVE fast. I'm gone for a week and a NEW center is already fabricated!
I have taken the speaker to an audio shop here in town to work out the crossover bugs and will report back as soon as I get it back. I will provide the crossover values so others can try this as well... I also have an extra csi-a6 cabinet and some drivers...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I will have the center back in a couple days. The crossover was so far out of spec for this thing it isn't even funny. He did a volume measurement for the cabinet, researches the specs for the 1.2tl's, tested the drivers, and all the other stuff I don't have the tools to do. He says this thing should rock when I get it back. I will post a list of components when I get it back.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Man, I wish I had an audio shop close by that I could talk to about building speakers.
SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality -
does anybody have an extra Signature Reference badge laying around?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I just got the center back, but it still is not as dynamic as I would like, so back it goes next week for some more tweeking...:(
JohnThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Do you know anyone who can make a square peg fits into a round hole? I guess using drivers in the wrong enclosure would be something like that....:)Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
You have the wrong woofers."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
any suggestions on woofers? My guy tells me it is only a matter of finding the right crossover point for them, but am open for suggestions.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
6510's, they're used in the RTA8L, which is a ported enclosure like yours. They still may not be perfect, but a better match.
What caps are you using, the original Polks?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I will look for a pair of them... The center is back at the shop already. He came and took it so he can work with it while I am out of town. I do not know what is in it yet.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
John
Have you tried a SDA CRS+ as a center channel? I've use it with great results. It'll save you alot of time and money. You could also TL it and run the RDO-198 tweeter. -
It is way to big for my fireplace mantle, but if anyone has a couple 6510's I would be grateful...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Are you using both woofers?John
Have you tried a SDA CRS+ as a center channel? I've use it with great results. It'll save you alot of time and money. You could also TL it and run the RDO-198 tweeter."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
nooshinjohn wrote: »It is way to big for my fireplace mantle, but if anyone has a couple 6510's I would be grateful...
John, I know it's probably been said, but what about changing the room around?
That way you are not as limited. I struggled with my H/T room for 3 years, then I finally broke down and said...OK Everything is getting changed...it took a lot of work but my room is 100% better now.
MOVE THE TV!
...and don't say you can't because you can.
Enjoy. -
How did you wire them up, did you make any changes to the crossover?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
john, just buy another 1.2tl and lay it on it's side. that will make a good center. =PTV: LG 55LW5600
Pre: Marantz SR6001
Front Amp: Parasound HCA-1000A
Center Amp: Marantz MA500
Mains: Polk LSi9
Center: Polk LSiC
Sub: HSU VTF-3 MK-2
Games: Xbox360 and PS3 -
Or....
You could get another 1.2TL and mount it on the wall above your TV.
Now THAT'S a center channel!!:p:eek:The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I have spent the past couple days making adjustments and listening to the center channel and I am pleased to report that it works beautifully. Whether i am listening to the news, sporting event, or 5.1 audio, the center is more than able to keep up with the big polks, It is clear, dynamic and precise, and serves as an invisible bridge to left/right, and holds dialog locked in the center where it belongs. I will be happy to provide crossover specs and have a few extra parts around for someone that is wanting to try one for themselves. It will take about two weeks for me to recover the cabinet in walnut veneer and post up some pictures of the finished speaker, but I am so happy that I kept with it as it is worthy of being called an SDA Center channel...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Any more pics?
I was wondering, for those of you running SDAs in a HT configuration....doesn't the SDA effect kinda get in the 'way' of a dedicated CENTER channel?
Just curious....as I've never tried it.
the key to it for me, is to have the center channel wrap into the left and right. It should almost not be heard at all. The reason I wanted to do this is to give the SDA's a more focused center point for tv watching and movies, especially for those that are outside the sweetspot, and so far it is working quite well. I am thinking of tweeking one of the drivers to deliver a bit more bass, but other than that, I really enjoy the sound. Having an RDO-198 delivering the highs really does provide the focus I have been looking for. I will post up some pics just as soon as I am able to finish the cosmetics, as for now it looks no different than it did a month ago.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
John, I was looking for the same effect for movie watching and now have achieved it with a Paradigm CC390 center. With my setup now I have quit tweaking it. The only thing left to do now is to do an upgrade on the 2.3 crossovers. Glad you're happy with your setup.
BillMy 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
Very nice work John. Congrats!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Bill
Heard the 390 last weekend and it sounded fantastic..actually good enough to make me pick one up for the wifes TV room, a very very nice center......... -
the adjustments have been completed with the speaker and the surround processor. I have been listening to various sources over the past couple days and I am convinced this center is just what I have been needing to effectively bredge the distance between the TL's in a 5.1/7.1 setup. The soundstage remains focused and dialog tightens up for movies, but it does so discreetly and without calling attention to itself. For music, it is both musical and detailed. I am very pleased with the results.:D
So pleased that I am going to call it the CSRS 1.2TL;)
I will post pictures of it when the walnut veneer is applied and the speaker is finished cosmeticallyThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
