Reference CD's and DVD's
Systems
Can anyone rec where to purchase CD's and DVD's to use as reference material? I like to play around with the settings on my system and feel it would be good if the disk had lots of short pieces of music/movies for comparison.
thanks,
thanks,
Testing
Testing
Testing
Testing
Testing
The Search feature is your friend... use it!Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier -
U-571 - Depth charges!!!:D
Transporter 3
Live Free-Die Hard
HellBoy 2
Beowulf
The Incredible Hulk
Max PayneLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
My reference CD is Joe Satriani - "Strange Beautiful Music"
and my reference DVD is "Saving Private Ryan" (Beachhead scene and defending the bridge scene)
- I especially recommend SPR if you use the DTS version.~Matt
My System
Front L/R: Definitive BP10Bs
Surrounds -Polk Audio Monitor 4As
Preamp: B&K Reference 20
CD: Jolida JD100a
L/R Amp: Carver TFM-24
Turntable: Pioneer PL-516 W/ Shure M97xe
TV: Sony 52" XBR9 -
I've posted this link before for DTS DVD's, but here it is again for your reference.
http://www.spannerworks.net/reference/10_6a.asp
Some of my recommendations:
Gladiator
Lord of the Rings-Two Towers
Spiderman 1 and 2 (Superbit)
Underworld (Superbit)
Master and Commander
Blade 2
Air Force One (Superbit)
Black Hawk Down (Superbit)
The Patriot (Superbit)
Apollo 13
War of the Worlds (Tom Cruise)
Black Hawk Down on superbit! I actually bought that years ago and have only listened to it on an old HTIB. I can't wait to check it out on my new system. thxTesting
Testing
Testing -
SPR is awesome! I will have to see if mine is DTS or not. thxTesting
Testing
Testing -
ken.paduch wrote: »SPR is awesome! I will have to see if mine is DTS or not. thx
Yeah if your version isn't DTS, you might consider going to the nearest CD exchange and trading it on the DTS version used if they have it. They'll probably look at you funny but they'll likely do an equal value trade +- a couple bucks depending on the condition.
I also sometimes use Apollo 13 launch scene for brute force reference.~Matt
My System
CD: Jolida JD100a
TV: Sony 52" XBR9 -
I'm surprised no one has mentioned a couple of Will Smith movies:
1) ID4 (exiting the "mother ship" towards the end of the movie)
2) I, Robot (the robots attacking car scene)
Yes, the depth charges in U-571 are ridiculous (for bass)Yamaha RX-A2050 AVR (5.0.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets
