Reference CD's and DVD's
Systems
Systems Posts: 14,872
edited June 2009 in Music & Movies
Can anyone rec where to purchase CD's and DVD's to use as reference material? I like to play around with the settings on my system and feel it would be good if the disk had lots of short pieces of music/movies for comparison.
thanks,
Testing
Testing
Testing
  • MrNightly
    MrNightly Posts: 3,370
    edited June 2009
    The Search feature is your friend... use it!
    Honoured to be, an original SOPA founding member
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    SVS PB12-NSD/2 - sub :D:D:D
    Denon 3805
    Rotel RB-985 5-Channel Amplifier
  • daboyz
    daboyz Posts: 5,207
    edited June 2009
    U-571 - Depth charges!!!:D
  • danz1906
    danz1906 Posts: 5,144
    edited June 2009
    Transporter 3
    Live Free-Die Hard
    HellBoy 2
    Beowulf
    The Incredible Hulk
    Max Payne
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Paden501
    Paden501 Posts: 286
    edited June 2009
    My reference CD is Joe Satriani - "Strange Beautiful Music"
    and my reference DVD is "Saving Private Ryan" (Beachhead scene and defending the bridge scene)
    - I especially recommend SPR if you use the DTS version.
    ~Matt
    My System
    Front L/R: Definitive BP10Bs
    Surrounds -Polk Audio Monitor 4As
    Preamp: B&K Reference 20
    CD: Jolida JD100a
    L/R Amp: Carver TFM-24
    Turntable: Pioneer PL-516 W/ Shure M97xe
    TV: Sony 52" XBR9
  • Systems
    edited June 2009
    Keiko wrote: »
    I've posted this link before for DTS DVD's, but here it is again for your reference.
    http://www.spannerworks.net/reference/10_6a.asp
    Some of my recommendations:
    Gladiator
    Lord of the Rings-Two Towers
    Spiderman 1 and 2 (Superbit)
    Underworld (Superbit)
    Master and Commander
    Blade 2
    Air Force One (Superbit)
    Black Hawk Down (Superbit)
    The Patriot (Superbit)
    Apollo 13
    War of the Worlds (Tom Cruise)
    Black Hawk Down on superbit! I actually bought that years ago and have only listened to it on an old HTIB. I can't wait to check it out on my new system. thx
    Testing
    Testing
    Testing
  • Systems
    edited June 2009
    SPR is awesome! I will have to see if mine is DTS or not. thx
    Testing
    Testing
    Testing
  • Paden501
    Paden501 Posts: 286
    edited June 2009
    ken.paduch wrote: »
    Yeah if your version isn't DTS, you might consider going to the nearest CD exchange and trading it on the DTS version used if they have it. They'll probably look at you funny but they'll likely do an equal value trade +- a couple bucks depending on the condition.
    I also sometimes use Apollo 13 launch scene for brute force reference.
    ~Matt
    My System
    CD: Jolida JD100a
    TV: Sony 52" XBR9
  • StantonZ
    StantonZ Posts: 454
    edited June 2009
    I'm surprised no one has mentioned a couple of Will Smith movies:
    1) ID4 (exiting the "mother ship" towards the end of the movie)
    2) I, Robot (the robots attacking car scene)
    Yes, the depth charges in U-571 are ridiculous (for bass)
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
