Thoughts on PS Audio - Juicebar II - Power Strip
thsmith
I would like to turn my attention to a better power strip/source. I have been upgrading my power cables and feel I am not taking advantage of the improvements in cables.
At the moment I am using a Home Depot Belkin 8 outlet surge protector.
The PS Audio Juicebar II is something I am considering.
ANy thoughts or suggestions?
WHat about something used on Audiogon ?
Thanks,
Thanks,
Post edited by thsmith on
Ps audio is great and you can find real good deals on audiogon.Or better yet get one of these..link>> http://www.b-p-t.com/power-centers.htmlSDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Thanks, looks like that unit has 6 outlets, I need 8.Speakers: SDA-1C (most all the goodies)
Sorry...I meant this one>>>>>>http://www.b-p-t.com/cpc-clean-power-center.htmlSDA-2BTL with custom IC
What about the Bpt model CPC non current limiting line conditioner. $339 on AudiogonSpeakers: SDA-1C (most all the goodies)
I will have to apolagize again as neither one comes with a the balanced isolation transformer which is what you want.That is the way to go.Try to find something that has a balanced design>>(I doubt you can find something with 8 outlets for cheap.)A ps audio UPC-200 would be good if you can find one,, or two since you need 8 outlets.
How about one of these >>http://www.audiogon.com/cgi-bin/cls.pl?powrcond&1249087644&/Ps-audio-quintet......Maybe you can wait for another to pop up if this one sells.SDA-2BTL with custom IC
FBM211, what do you mean by balanced design ?Speakers: SDA-1C (most all the goodies)
Check Audiogon for Panamax, I just looked there a few days back and there were some awesome deals. If youre not against monster power you will find some deals on those also.Shoot the jumper.....................BALLIN.............!!!!!
thsmith, what are you looking for? A surge suppressor? A line conditioner?
The Juicebar II is neither of the above, its just a quality non-current limiting outlet extender. It uses the same Power port outlets sold separately for the wall.
They have a very tight grip-no worry about loose cables or poor contact.
What do you need 8 outlets for? Perhaps you might consider 2 dedicated outlets, each with its own Juicebar. Of course if you also get a conditioner, its likely you not need to use all 8 outlets on a single Juicebar anyway (if that's the way you want to go).____________________
Pool: Atrium 60's/45's -
Only what I have read in other threads.Its to technical for me to get into as I would have to look up the info and other posts that I read on it.I was looking for the same thing as you were a few weeks ago.Here is a link to that thread.>> http://www.polkaudio.com/forums/showthread.php?t=83136
The APC AV H15 is a solid choice.SDA-2BTL with custom IC
I would like a surge suppressor and line conditioner.Speakers: SDA-1C (most all the goodies)
