Got a pair of SDA-1C that need refurbishing
Ender
Ender Posts: 603
edited July 2009 in DIY, Mods & Tweaks
Cosmetically, looks like **** on the top and the sides. The front is near perfect though, strangely enough.
So for the top caps, there are marks, scratches, water cup marks, etc. Is it possible to sand it down and refinish? These are solid wood caps I believe.
Otherwise, I will just purchase some wood cuts and sand them down and finish them myself. Might as well get the experience if I am to refurbish my SRS 2, anyhow. If I need to do this, where should I buy the wood and what tools should I use for the cutting like the round corner cuts and rounded edges? Jigsaw and router?
Then for the sides, the grill boards are falling off. The glue is really weak at this point. How should I go about restoring these? I really like the look that nooshinjohn accomplished with his 1C: http://www.polkaudio.com/forums/showcase/view.php?userid=92017
Then I can have my SRS 2 and a mini-SRS 2 lookalike!!! Lol.
Do I need to remove glue under these side panels before I attach new side panels? If so, how do I go about doing that without ruining the actual cabinet?
SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality
Post edited by Ender on
  • george daniel
    george daniel Posts: 12,096
    edited June 2009
    I would suggest that you contact the resident "Wood Ninja" on this one.Good luck with the rehab.The 1C's are just a fun SDA to own.:)
  • Conradicles
    Conradicles Posts: 6,366
    edited June 2009
    nooshinjohn Posts: 25,962
    edited June 2009
    You might want to check out mine...
    I updated the look a bit by finishing them in cherry and going for an SRS look side panel.
  • Ender
    Ender Posts: 603
    edited June 2009
    This thread may help a little. Enjoy!
    http://www.polkaudio.com/forums/showthread.php?t=77694
    Yeah, I subscribed to this thread. But it still doesn't help me with how to get started and such. Thanks for the rec though.
    Lol. I have this posted in my OP. Thanks for keeping the photos up! I am aspiring to this build. :)
    Are we talking about F1Nut?
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2009
    Ender wrote: »
    Yes!
  • george daniel
    edited June 2009
    Ender wrote: »
    he, he,, Who else,, you might have to wait until the sun sets though.;)
  • xj4094dg
    xj4094dg Posts: 1,158
    edited June 2009
    Brad Pitt in Thelma and Louise. He bones the Gina Davis character I think. Had no idea who he was at the time.
    "The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
  • george daniel
    edited June 2009
    xj4094dg wrote: »
    brad pitt in thelma and louise. He bones the gina davis character i think. Had no idea who he was at the time.
    wth ??
  • Ender
    Ender Posts: 603
    edited June 2009
    wth ??
    I believe he gave you who else to consider might be the "Wood Ninja". Lol.
  • george daniel
    edited June 2009
    Ender wrote: »
    Well,, he threw that one by me.:)
  • ben62670
    ben62670 Posts: 15,969
    edited June 2009
    I have some real wood laminate. You have seen my projects...
    Ben
  • Ender
    Ender Posts: 603
    edited June 2009
    Yeah. But I really like the idea of solid wood, despite its shortcomings. Lol.
    Btw... should I message F1Nut to get his opinion?
  • Conradicles
    edited June 2009
    Polkies...What kind of glue is the best to hold the side grill pieces of wood on to the cabinet? Also, the best glue for the wood end caps onto the cabinet.
  • george daniel
    edited June 2009
    for the side panels,I've had good luck with gorilla glue,, i think that you will get as many answers to this as the cable debates,LOL,,I just lay the speaker on it's side,and add something heavy to the panel,,wait a day,,good to go,,good luck
    edited June 2009
    I like gorilla grip and hot glue gun. I first apply gorilla grip to the cabinet, leaving areas for the hot glue to be applied. I then place hot glue at the top and positing the piece, then continue down the cabinet until the piece is held in place by the hot glue. Gorilla grip expands significantly as it dries, so care must be used to make certain you do not end up with glue where you do not want it to be...
  • Ender
    Ender Posts: 603
    edited June 2009
    Cool. What should I do to remove the old glue? Just slowly scrape it off? Maybe use a heat gun too?
  • Conradicles
    edited June 2009
    I used a small chisel and scraped it off yesterday on mine. Worked pretty good then I sanded it a little bit.
    I'm going to do the Mortite and Driver Basket Foam mods in the next day or so.
  • Ender
    Ender Posts: 603
    edited June 2009
    Sounds good. What about the caps? Someone mentioned somewhere that it was a bit harder to remove without causing damage to the cabinet or caps or something? Is that true?
    Toolfan66 Posts: 18,129
    edited June 2009
    I think your caps are just bolted on,if you pull the passive radiator look inside. My SDA2's were stapled and glued.
  • Ender
    Ender Posts: 603
    edited June 2009
    edited June 2009
    I stand corrected.
  • Ender
    Ender Posts: 603
    edited June 2009
    Lol. My SDA SRS 2 caps were bolted on though. But I am afraid of removing the caps without someone's advice on how to remove them. I am thinking of just getting a chisel in there and slowly working away at it, but... I am unsure.
    edited June 2009
    Ender wrote: »
    That appears to be the best way. Just be certain to work your way around slowly, and work them loose a little at a time.:)
  • jimbo1421
    jimbo1421 Posts: 772
    edited June 2009
    Ender wrote: »
    Can't you remove the drivers and unscrew them from the inside?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    Parasound P3 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
    edited June 2009
    nope... they are glued on and then stapled together from the inside...
  • Conradicles
    edited June 2009
    The caps were easy. Just tap a chisel with the bevel up into the joint in the back of the speaker and wiggle a bit and you will see separation. Then just work your way around and it will come off. Mine had 4 staples and was barely glued.
    Now they are sent off getting pimped by Nick.
    heiney9 Posts: 25,487
    edited June 2009
    Ender wrote: »
    A large (wide) bladed paint scraper works very well for the side panels on the 1C's since they are glued on.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited June 2009
    If you are going to discard the original caps/tops...I used a small wooden block and a rubber mallet to get the old caps on the leading edge to start to come loose.
    A wide pry bar will also work fine,as long as you don't put pressure on the top edge of the cabinet itself...which can leave a impression.
    A small grinder will take off the staples that are coming through the top of the cabinet.
    Very simple,once you get them started to come loose.
  • Conradicles
    edited July 2009
    I used some Liquid Nails this past weekend and it worked like a charm.
    My top caps painted by Nik should be here Friday, so I'll post some pictures this weekend.
  • Ender
    Ender Posts: 603
    edited July 2009
    Nice! Thank you. I am still having trouble getting rid of the side panels. One of them seem to be stuck on pretty good and I am afraid of taking a scraper to them too hard because it might damage the actual enclosure...
