Help with Blue Ray Player
woodhead 2
Bought a Samsung BD1600 Blue Ray Player, and have a Samsung 72" wide screen DLP TV. When I play a disc, I have a bar on top and a bar on the bottom of the screen. I have the TV and the player set for widescreen. Is this normal for Blue Ray?? If it is, this really sucks.
Panny 8000 project
Oppo 103D
Fronts- Monitor 70's
Upper fronts- Monitor 30's
Surrounds- Monitor 50's
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
Onkyo 607[back up]
Oppo 103D
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
Onkyo 607[back up]
Post edited by woodhead 2 on
Depends on what movie. What movie are you watching?
Your tv is 16:9 (1.85:1) ratio, which some movies are. Most movies are 2.35:1, which is much wider. To show it correctly, it will have black bars, this is normal.
To check if the player is set up correctly, remove the disc from it, and go into the setup menu. Make sure the screen type/size is set to Widescreen or 16:9, not 4:3 or Normal.
Also, are you using HDMI as your connection type?Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Yes, it's normal. You should have picture size adjustments on the TV that will eliminate it, but it cuts a little of the picture off each side.
it's normal.. with so many widescreen formats.. even 16:9 LCD/plasma tv's don't format all movies correctly.. sucks assss. (it's not a problem with the TV's.. it's the studio's that release movies in many different formats.PolkFest 2012, who's going>?
Just get a tv with a really good black level and watch them with the lights out.
Main Surround -
danger boy wrote: »it's normal.. with so many widescreen formats.. even 16:9 LCD/plasma tv's don't format all movies correctly.. sucks assss. (it's not a problem with the TV's.. it's the studio's that release movies in many different formats.
Your not kidding it sucks. Spend all that cash on equipment, and you have to put up with that.Panny 8000 project
Oppo 103D
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
Onkyo 607[back up] -
Yup, HDMI for conection. I bought the Grand Torino, and the Wrestler. Both of them had the black bars on top mand bottom. Both Tv and Blue Ray player are set to widescreen.Panny 8000 project
Oppo 103D
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
woodhead 2 wrote: »Your not kidding it sucks. Spend all that cash on equipment, and you have to put up with that.
If you are a "typical" human, and are actually interested in the movie, then the black bars typically disappear from your sight.
Studies have proven that an average person's mind will "stretch" out the picture, so that the person no longer sees the black bars. Basically, the only way really be bothered by it is by conciously noticing it (by crying, for instance).
Just focus on and enjoy your movies, and you'll hardly even notice the bars!
Besides, if you have black bars then you can be sure you're seeing the movie how the director saw it, and therefor how he WANTS you to see it."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
Woodhead,
Sorry to see that you are not happy but how much time did you spend researching about HD, Blue-ray and movie aspect ratio's before you went out and plunked you $$$ down? I know that those numbers listed in the specifications are confusing but they are very important. Once again I am sorry to hear that you are not happy.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
thuffman03 wrote: »Woodhead,
Sorry to see that you are not happy but how much time did you spend researching about HD, Blue-ray and movie aspect ratio's before you went out and plunked you $$$ down?.
It's not just Blu-Ray, you get the same black bars with DVD's. It's been that way for a decade. -
if you really hate it, hit zoom on your tv until it crops the sides off and makes the black bars disappear.Main Surround -
Ya, I should of done more research. Live and learn....Panny 8000 project
Oppo 103D
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
Onkyo 607[back up]
