Denon DP-500M Turntable and DL-160 Cartridge
haimoc
haimoc Posts: 1,031
edited June 2009 in 2 Channel Audio
I can't resist on a great deal package of new Denon DP-500M Turntable and DL-160 Cartridge. Here are some pictures...
I hate manual turntable because it is too much work for me, but it sounds so GOOD with dead silent operation..
Post edited by haimoc on
    edited June 2009
    Nice looking TT there buddy boy.How good of a deal are we talking? Only asking because I've been meaning to try out some records,after 30 years,again,but don't want to spend the nest egg,know what I mean ?
  • haimoc
    haimoc Posts: 1,031
    edited June 2009
    tonyb wrote: »
    Sure.. Tony... It was $600.00 for both turntable and cartridge... I think it is a steal because both are new in boxes... :)
    Honestly, I found that I like this turntable better than Project RM9 that I used to have with Sumiko Blackbird cartridge and my buddy's Music Hall 9.1. It is just my opinion... not to offend anyone who owns Project or Music Hall.
  • thuffman03
    thuffman03 Posts: 1,325
    edited June 2009
    That is one pretty nice looking table. I need to get one soon.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • thsmith
    thsmith Posts: 6,082
    edited June 2009
    Not familier with that TT but it sure is pretty. The DL-160 is a sweet cart. I have one on my Technics SL-1300
  • haimoc
    haimoc Posts: 1,031
    edited June 2009
    thsmith wrote: »
    Yes, the cart is very nice.. and I like the cartridge alignment template that comes with it. It is easy tool to use.
  • thsmith
    edited June 2009
    Humm, I did not get an alignment template with my Denon.
    Never mind I think you were referring to the TT not the cart.
  • Systems
    Systems Posts: 14,872
    edited June 2009
    That DL-160 is a sweet cart. Do yourself a favor and have the TT serviced if it hasn't been done so in a long time. The cart alignment tool is pretty good but I'd like to use a respectable protractor and some software like Visual Analyzer 8.14 connected to a computer or laptop via the line input on the laptop and the line output/tape monitor on your rec/preamp. This is a sweet way to really dial in a TT. You will need a test LP with tones to do this but it can make a terrific difference in performance. Easy to use.
    Just my $.02
    Testing
    Testing
    Testing
  • jon s
    jon s Posts: 905
    edited June 2009
    the DPM-500 is a current model TT....
  • Systems
    edited June 2009
    oops...I missed the new part. Sorry
    Testing
    Testing
    Testing
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2009
    That's a nice looking turntable.
  • haimoc
    haimoc Posts: 1,031
    edited June 2009
    Thanks all for nice words and advice.
    I am going to get Turntable Basics' Phono Cartridge Alignment Tool and Stylus Force Gauge, shortly.
