Denon DP-500M Turntable and DL-160 Cartridge
haimoc
I can't resist on a great deal package of new Denon DP-500M Turntable and DL-160 Cartridge. Here are some pictures...
I hate manual turntable because it is too much work for me, but it sounds so GOOD with dead silent operation..
Nice looking TT there buddy boy.How good of a deal are we talking? Only asking because I've been meaning to try out some records,after 30 years,again,but don't want to spend the nest egg,know what I mean ?HT SYSTEM-
lsi 9's -
Sure.. Tony... It was $600.00 for both turntable and cartridge... I think it is a steal because both are new in boxes...
Honestly, I found that I like this turntable better than Project RM9 that I used to have with Sumiko Blackbird cartridge and my buddy's Music Hall 9.1. It is just my opinion... not to offend anyone who owns Project or Music Hall. -
That is one pretty nice looking table. I need to get one soon.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
Not familier with that TT but it sure is pretty. The DL-160 is a sweet cart. I have one on my Technics SL-1300Speakers: SDA-1C (most all the goodies)
Yes, the cart is very nice.. and I like the cartridge alignment template that comes with it. It is easy tool to use. -
Humm, I did not get an alignment template with my Denon.
Never mind I think you were referring to the TT not the cart.Speakers: SDA-1C (most all the goodies)
That DL-160 is a sweet cart. Do yourself a favor and have the TT serviced if it hasn't been done so in a long time. The cart alignment tool is pretty good but I'd like to use a respectable protractor and some software like Visual Analyzer 8.14 connected to a computer or laptop via the line input on the laptop and the line output/tape monitor on your rec/preamp. This is a sweet way to really dial in a TT. You will need a test LP with tones to do this but it can make a terrific difference in performance. Easy to use.
Just my $.02Testing
Testing
Testing -
the DPM-500 is a current model TT....
That's a nice looking turntable.
Thanks all for nice words and advice.
I am going to get Turntable Basics' Phono Cartridge Alignment Tool and Stylus Force Gauge, shortly.
