Darqueknight I have powercable you need to test for its benefits . . .
SolidSqual
SolidSqual Posts: 5,218
edited June 2009 in 2 Channel Audio
I am a believer of many high-end cables, but come' on . . . seriously?
http://cgi.audiogon.com/cgi-bin/auc.pl?powrcabl&1245892591&1245315155
I"m not going to lie. If I had spare outlets, I would wire my whole system with this crap purely to make people think I am more nuts.
Post edited by SolidSqual on
  • SolidSqual
    edited June 2009
  • concealer404
    concealer404 Posts: 7,440
    edited June 2009
    Dude, that's awesome! It gives you more voltage and stability and all that! Duh!
    Wait....
  • NotaSuv
    NotaSuv Posts: 3,871
    edited June 2009
    wow now I know where the missing hose from my hookah went.......
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2009
    Wow...I think that's a little overboard. I'll probably pick up some Signal Cable Magic Power cables for my 2 channel rig eventually...but that's probably about as far as I'll ever go down the PC path.
    Those cables are ridiculous...IMHO. The second one has an asking price of 3800 dollars? If you have that much money to spend on a power cable...I hope you're donating some money to charity or something too every year.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited June 2009
    For much less than $3800, a good power conditioner or AC regenerator ($1100 or less on the used market) combined with a modestly priced ($500 or less on the used market) well engineered power cable should way outperform this, particularly if you are not getting reasonably clean power from the utility company to begin with. There is only so much that passive power filtration devices (cords, receptacles, noise filters) can do.
