Computer HD ?
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2009
    WilliamM2 wrote: »
    That drive should have a three year warranty. Go here, check the warranty staus, and request a replacement :
    http://216.102.195.13/gcs/toshiba/
    I don't believe it I got a RMA #, now what? Would you use a Toshiba drive for an USB portable drive? Would you have that much faith in it?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • wizzy
    wizzy Posts: 867
    edited June 2009
    disneyjoe7 wrote: »
    Put it in an external USB case and use it to backup files from the laptop. That's what I did with the drive I took out of my notebook after replacing it with a larger one.
  • John30_30
    John30_30 Posts: 1,024
    edited June 2009
    appadv wrote: »
    Whooops, I've used my APC Smart-UPS 1500 to power a drill and other power tools when there is no outlet around. I've run it completely out of battery a few times.
    I don't buy what he says about killing UPS batteries running them way down. These are not car batteries, nor marine batteries, they're designed for running down to zilch. I've done it many times, as the power grid here is terrible. What they do is last 4-5 years as advertised, then caput.
  • John30_30
    edited June 2009
    Ender wrote: »
    Oh, also, you might want to check out your power supply. I've known cases where computers would use unreliable power supplies which results in the motherboard, hard drive, or CPU dying. Most power supply brands and product lines are not reliable, especially when it comes from pre-assembled big names like Dell or HP.
    That's good advice on any desktop machine. However, he's talking about his laptops AC to DC supply, not desktops, and generally laptop power bricks are very reliable.
  • wizzy
    wizzy Posts: 867
    edited June 2009
    John30_30 wrote: »
    Yeah, why listen to someone with 20 some years working in data centers.
    What the hell does he know?
    Try a google search. Something like:
    UPS battery discharge life
    would be a good start.
  • disneyjoe7
    edited June 2009
    Well this drive looking at by S.M.A.R.T shows "Reallocator Sector Count" as the trouble. Looking at smart by the green bars shows nothing at this table, where all others are nice and strong. Is this drive really shot? You couldn't low level format or anything?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited June 2009
    disneyjoe7 wrote: »
    It needs to be replaced. As far as whether I would trust the replacement, I'd trust it just as much as any laptop drive. I've seen failures from all the manufacturers.
  • disneyjoe7
    edited June 2009
    Great William, I'll return that drive so I can get another drive to play with.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • wizzy
    wizzy Posts: 867
    edited June 2009
    I'm shocked they gave you a replacement ... normally when I've tried any OEM drive it's always "oh, it's OEM, call the manufacturer" which basically means it's past 1 year, you are SOL
  • disneyjoe7
    edited June 2009
    Yes I had this happen with a WD drive in a TiVo. :( So I'm surprised about it also, when I put part # in then serial # I was think the next screen is going to state SOL.... But never did :D
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • WilliamM2
    edited June 2009
    All manufacturers have at least 3 years on OEM drives. I've never had a problem getting a replacement for an OEM computer. Devices like TIVO's may be different.
  • wizzy
    wizzy Posts: 867
    edited June 2009
    WilliamM2 wrote: »
    I think we're talking about two different things here. There is OEM as in you ordered it from newegg/amazon/etc and it had no box or cables OEM, in which case yes you may normally will get a three year warranty.
    Then there is OEM as in it came pre-installed in a computer, TiVo, external case, laptop, etc. in which case many times the manufacturer provides no warranty whatsoever. In return for a massive discount to the equipment maker, the equipment maker provides all warranty services and the hard drive manufacturer provides none.
    W
