Rear Center
When the term "rear center" is used, is it the same as "surround back"? I'm assuming a rear center would be used in a 6.1 system?
-Bryan
Equipment Used:
AVR: Sony STR-DA3000ES Digital 7.1
Front: RT2000i
Center: CS400i
Surround: f/x500i
Surr. Back: FXi50
Floor Sub: Infinity BU2
Equipment Used:
Front: RT2000i
Center: CS400i
Surround: f/x500i
Surr. Back: FXi50
Post edited by bryanr72 on
I think you have it all figured out. A rear center is describing the surround back channel in a 6.1 setup. It may be that, because many people choose to use a center speaker -- convenient because it's easier to find 1 center than 1 bookshelf -- in a 6.1 configuration for the surround rear, that it's description has morphed into 'rear center.' Just a guess.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
Just my opinion, but to me it would make more sense to buy a pair of book shelf speakers. Maybe you only get to use 1 of them at this moment, if you have a 6.1 setup, but if everything starts becoming 7.1 down the road, then you have to go find a pair of speakers to replace the back center.
-Bryan
Equipment Used:
Front: RT2000i
Center: CS400i
Surround: f/x500i
Surr. Back: FXi50
Floor Sub: Infinity BU2 -
If your HT room is small or medium, mine is medium, I don't think that the benefit of 7.1 would be that big over 6.1. Even if I was 7.1 ready I would stay 6.1, I have enough speakers on the walls now
Center channel for the rear is my route.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
