Rear Center
bryanr72
bryanr72 Posts: 53
edited August 2003 in Speakers
When the term "rear center" is used, is it the same as "surround back"? I'm assuming a rear center would be used in a 6.1 system?
-Bryan
Equipment Used:
AVR: Sony STR-DA3000ES Digital 7.1
Front: RT2000i
Center: CS400i
Surround: f/x500i
Surr. Back: FXi50
Floor Sub: Infinity BU2
Post edited by bryanr72 on
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited August 2003
    I think you have it all figured out. A rear center is describing the surround back channel in a 6.1 setup. It may be that, because many people choose to use a center speaker -- convenient because it's easier to find 1 center than 1 bookshelf -- in a 6.1 configuration for the surround rear, that it's description has morphed into 'rear center.' Just a guess.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • bryanr72
    bryanr72 Posts: 53
    edited August 2003
    Just my opinion, but to me it would make more sense to buy a pair of book shelf speakers. Maybe you only get to use 1 of them at this moment, if you have a 6.1 setup, but if everything starts becoming 7.1 down the road, then you have to go find a pair of speakers to replace the back center.
    -Bryan
    Equipment Used:
    Front: RT2000i
    Center: CS400i
    Surround: f/x500i
    Surr. Back: FXi50
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2003
    If your HT room is small or medium, mine is medium, I don't think that the benefit of 7.1 would be that big over 6.1. Even if I was 7.1 ready I would stay 6.1, I have enough speakers on the walls now :)
    Center channel for the rear is my route.
