best way to hook up two subs
glemay
Here is my setup:
AMP - Technics Stereo Intergrated Amplifier SU-V97
EQAULIZER - Technics Stereo Graphic Eqaulizer SH-8033
TUNER - Technics Synthesizer AM/FM Stereo Tuner ST-S77
SPEAKERS - Polk Audio RTi70
SUBWOOFERS - Polk Audio PSW202
- Sound Dynamics THS 3000
CABLE - Home Depot 12 Gauge
What would be the best way to hook up the two subwoofers? I don't really know what the most efficent way is. The Sound Dynamics THS 3000 Subwoofer is down firing and my floor in my bedroom is carpet, I was thinking about making up a piece of 1/4" plate aluminum and placing it underneath. Is that a good idea? Where should I place the two subwoofers, my room is fairly large, 20' x 13'. By the way I am planning on buying a Harman Kardon HK3475, so the Technics will be gone shortly!
Tell me what you think.
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Second System:
Post edited by glemay on
Just split the sub out from your receiver, & run it to the subs. Make sure you put the subs close together, or stack them on to of each other. Any-more qs Dr Spec will know!!!My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
I agree with Groove Holmes
Stack em and throw em in the cornor. I have spent countless hours moving and adjusting and this and that, and to my satisfaction stacked in the cornor is the best for way in a large room. For me anyways. I belevie you gain 3db for stacking them alone. Make sure you have your more powerful amp turned up more than your "smaller" one.
_______________________________________________
Onkyo TXSR500
Mains RTi70's
Center Csi30
Subs PSW350, PSW404 (Stacked)
Rears Kendwood Junkies
Dog - Pit Bull Terrier ADBA reg....????
"Ummmmm melted hog fat" - H. SimpsonLife without music would♭ -
Good approach here would be to calibrate each to same level at a frequency they can both reach.Originally posted by spasticpitbull
Make sure you have your more powerful amp turned up more than your "smaller" one.More later,
Tour...
Vox Copuli
