RC80i in-ceiling and 130 watt Onkyo SR806
jmtudor
jmtudor Posts: 4
edited June 2009 in Speakers
I am considering purchasing the Onkyo SR806 rated at 130 watts per channel. I need to install in-ceiling speakers. Two questions:
1) RC80i is rated at 100 watts, will this be a foolish match to the Onkyo considered above, should I instead look at the 706 which is rated at 100 watts?
2) Would it be acceptable to install 7 of the RC80i, using this speaker for all 7 channels (center, surround, etc.)? Also seeing if I have wall room for two rear speakers and looking at the RC85i.
My ceilings are 10 feet, the room is odd dimensions opening up into dining and kitchen areas so am wall-challenged.
Thank you for any advice!
Post edited by jmtudor on
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2009
    Welcome to Club Polk. Your speakers will be just fine with the Onkyo 806. More speakers are damaged by being over driven with too little power rather than too much power.
    What's more is in the future, you can purchase a separate amplifier for more power to ensure that your speakers are getting all the power they need to operate to their full potential with the 806.
  • jmtudor
    jmtudor Posts: 4
    edited June 2009
    Awesome. Thank you, do you have any opinion on the second question--designing a 7.1 system, would the RC80i work as a center speaker?
  • jmtudor
    jmtudor Posts: 4
    edited June 2009
    Below are options I am considering. 2 in-wall speakers for the rear surround, 4 in-ceiling speakers for all but the center and the woofer. I have a woofer already but one purchased 10 years ago from Radio Shack for about $300 and not sure the specs. Not that interested in upgrading it, from my experience not sure if the woofer is all that critical but open to suggestions on that.
    Onkyo TX-SR806 Receiver
    Polk Audio RC80i in-ceiling Speakers
    Polk Audio RC85i in-wall Speakers
    Samsung BD3600 Blu Ray player
    Polk Audio CS20 Center Speaker
    Polk Audio Csi A6 Center Speaker
    Polk Audio PSW125 Woofer
  • jmtudor
    jmtudor Posts: 4
    edited June 2009
    Got it. thanks for the reply.
  • I am building a covered patio. I will have two zones with 2-RC80i ceiling speakers/zone. I am now considering what amplifier to use. Given its functionality, I would like to use the WiiM Amp for each zone. This amp has 60watt power, and reviewers have stated it works well up to a sensitivity level of 93db. In your opinion would this amplifier be adequate to drive two RC80i ceiling speakers?
  • rooftop59
    rooftop59 Posts: 8,120
    GGetgen wrote: »
    Those speakers aren’t difficult to drive. You should be fine. Of course, more power is better all other things being equal, but you’ll be fine.
    Game Room 5.1.4:
    Bedroom 2.1
