any way to repair warped vinyl ?
nooshinjohn
Just curious if anyone have repaired warped vinyl without damaging the LP. I found a sealed copy of Crystal Gayle's first lP and when I try and play it the stylus bounces in th groove of the first couple tracks.. Any ideas?
Post edited by nooshinjohn on
Yep there are warped vinyl repair devices out there. Look here for a thread on just such a machine. Did it begin with an "F"? Furman? I can't remember where I saw it. Clearaudio makes one too if I remember. I have used a steam cleaner and carefully heated the vinyl until it softened a little. Then while still warm I use a stiff cleaning brush like the one from VPI with a little cleaning fluid as a lubricant. As the vinyl cools I'm pressing as if to clean and I have been able to take warpage out of some LP's. But you have to be careful.Testing
Testing
Testing -
Slightly increase the stylus pressure when playing it or get a tonearm that will track better.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
on the LP I want to fix, there is a 1/4 inch drop over a 1/4 inch. I have adjusted the downforce but that is not enought to compensate for what is essentially a speedbump in the vinyl. I am going to try a blowdrier or something on a very flat surface and gently massage that edge...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Get a reflex clamp.
Took the words right out of my mouth.
Try this one although you are going to need some shims which I have.
http://store.acousticsounds.com/browse_detail.cfm?Title_ID=36249
You should be using a record clamp anyway on all your records being played. It transforms the music like no other tweak for vinyl. -
Place between 2 large panes of double strength glass and expose to strong direct sunlight. Don't leave un-attended!! As soon as the warp is "relaxed", put the "sandwich" inside on a flat surface to cool and set.;)
Some members went together and bought a Furman. Word is it works great. They are sharing it between each of them that participated.engtaz
It's Furutech, and yes, it does work amazingly well. Here's a sample I captured.
Before:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/hFp7bUqu_TU&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/hFp7bUqu_TU&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
After:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/9XA6dtYoyaM&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/9XA6dtYoyaM&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>_________________________________________________
I wish I could afford the box for this thing... can I send a few albums out to someone that has one of these things. I will pay for shipping both ways and a bit for your time as well.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »I wish I could afford the box for this thing... can I send a few albums out to someone that has one of these things. I will pay for shipping both ways and a bit for your time as well.
Just buy CD's or get a IPOD. Problem solved.:p -
IPOD? You need to be slapped for that one. :eek:~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
... ummm, I don't know where to go with that one. I have not played a cd on my rig since the TT got here. I just got a new cd/dvd/blu-ray and it has only been played long enough to see that it works.Just buy CD's or get a IPOD. Problem solved.:p
Don't slap Leroy for that... we can hang him in effigy and burn him at the next C/P get-together instead:pThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
But why? I can't hear how compressed my MP3s are through my iPod buds anyway.
I just found this link. I may have to try this just to satisfy my curiosity.
http://www.angelfire.com/fl5/roadhouse/warped.html
I like this one... I will try it this weekend and report backThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
