Affordable good looking cables.
Matt34
Matt34 Posts: 318
edited June 2009 in 2 Channel Audio
I'm looking for some good looking cables in about 6-8ft length terminated with Banana plugs. I'm not interested in how a cable "sounds", just want something that looks nice for the living room HT setup. Would like to to keep it under $150/pr.
Here is what I'm looking at now.
http://www.ascendacoustics.com/pages/products/access/cable/matrixspkr.html
Post edited by Matt34 on
  • danz1906
    danz1906 Posts: 5,144
    edited June 2009
    Try JonBilt cables, They look good and sound even better:D
    sales.jonbilt@comcast.net
    http://www.polkaudio.com/forums/showthread.php?t=84140
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • thsmith
    thsmith Posts: 6,082
    edited June 2009
    For that length and amount you are willing to spend you should be able to achieve both.
    Personally I prefer function over form, but thats just me.
  • ben62670
    ben62670 Posts: 15,969
    edited June 2009
    I like Video for visuals and audio for sound. Lets not get confused.
    Ben
  • tcrossma
    tcrossma Posts: 1,301
    edited June 2009
    What looks good to you? Thick cables, shiny cables, colorful cables, cables with patterns? I prefer to start with a cable that sounds good, but if sound doesn't much matter to you I'd say just look over some websites and find something that fits your idea of what looks good and go with it.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • blueboxer
    blueboxer Posts: 621
    edited June 2009
    If you want a custom design or look, check out Elemental Design. I think their site is edesignaudio.com
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited June 2009
    I would go for a good sounding cable. Most good sounding cables are also relatively good looking.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • Matt34
    Matt34 Posts: 318
    edited June 2009
    blueboxer wrote: »
    Thanks, didn't know they carried any cables.
  • Face
    Face Posts: 14,340
    edited June 2009
  • pearsall001
    pearsall001 Posts: 5,325
    edited June 2009
    Face wrote: »
    Ah, the pixie dust company. :p
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited June 2009
    www.viperav.com
    Try these guys out. Email sales@viperav.com for a qoute. (Much less than the prices quoted on the site).
    Can't vouch for the SQ, but I think they look nice. A full set of 5 ought to cost you something like $100 to 150.
  • jm1
    jm1 Posts: 618
    edited June 2009
    Matt34 wrote: »
    Speaker cables: cheap. Sonic characteristics: irrelevant. Memory of this thread: priceless.
    All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
    Arthur Schopenhauer
    VR3 Posts: 29,534
    edited June 2009
    I found some Belkin Pure AV --
    Incredibly nice, thick looking cables...
    $40.00 bucks shipped...
    http://www.expansys-usa.com/p.aspx?i=152145&partner=froogle
    I saw the price on EBay
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited June 2009
    jm1 wrote: »
    The Train Ride to the bottom continues.
    RT1
  • Matt34
    Matt34 Posts: 318
    edited June 2009
    jm1 wrote: »
    Thanks for contributing.
  • george daniel
    george daniel Posts: 12,096
    edited June 2009
    Matt34 wrote: »
    You are not serious about not caring how they sound,,right? You really are not going to buy a SC based upon looks,,are you? Say it ain't so.
    F1nut Posts: 51,944
    edited June 2009
    Don't be surprised folks, this troll is a moderator on Audioholics. 'Nuff said.
  • Matt34
    Matt34 Posts: 318
    edited June 2009
    I went with the Ultralink MX-2, thanks to those that provided other options.
    treitz3 Posts: 20,082
    edited June 2009
    No wonder I don't visit that website for anything valid. This thread speaks for itself.
  • MLZ
    MLZ Posts: 214
    edited June 2009
    Its easy to make your own - I used Canare 4s11 and TechFlex (you can choose your color / pattern) I did use a paint stripper heat gun to do the heat shrink.
    http://www.avsforum.com/avs-vb/showthread.php?t=776636
  • Matt34
    Matt34 Posts: 318
    edited June 2009
    MLZ wrote: »
    I've used his guide before to make my own as well but I keep having the banana plugs pull off them.
  • reeltrouble1
    edited June 2009
    treitz3 wrote: »
    +1 tom
    You know I remember when the biggest AGENDA item here was what brand of ****-gasket RussMan recommended during a full-on rear end blowout.
    RT1
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2009
    Hm...Personally, I've never even counted cable aesthetics as a factor. I don't spend a lot of time looking at them really. I'm usually a little more involved in the tunes though I suppose...
    I think I'd have to put quality and tonal characteristics over the appearance, but to each their own I guess.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • strider
    strider Posts: 2,568
    edited June 2009
    Have you seen these new connectors from Neutrik? They're decorated with Swarovski crystals, may be perfect for you?
    http://www.neutrik.com/fl/en/audio/204_1794491862/crystalCON_productlist.aspx
    Wristwatch--->Crisco
  • Matt34
    Matt34 Posts: 318
    edited June 2009
    I just wanted some recommendations on some nice looking cables for my home theater setup that is in the living room, not my dedicated 2-channel setup. Since this is a very subjective hobby it's silly to ask for recommendations on "good sounding" cables because each of us obviously hear differently and none of us have the same rigs. As long as they are properly constructed I doubt I will here differences in the cables anyhow. Three tours to Iraq have left my hearing somewhat deminished.
    I'm gald I could provide a laugh for some of you.:rolleyes:
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2009
    Matt34 wrote: »
    Thanks for your service for our country Matt.
  • tcrossma
    edited June 2009
    Matt34 wrote: »
    What looks good is pretty subjective too, as everyone has different tastes and opinions about what a "good looking" cable should actually look like. But oh well, sounds like you found what you were looking for, so all is good.
    F1nut Posts: 51,944
    edited June 2009
    strider wrote: »
    Dem's purdy.
    edited June 2009
    Hey Matt, have you thought about the Magic Pebbles? Your system could have the look, the shine, reflections and a small vile that would complete the look of the great looking wires you seek to possess.
    Matt34 wrote:
    Three tours to Iraq have left my audio priorities somewhat FUBAR'D.
    Here, I corrected that for you. Though we all would like to thank you for your service to our beloved country, you have come to the wrong board to ask for good "looking" cables. If you are looking to improve the sound of your rig, that's one thing.....but looks? :rolleyes:
  • Matt34
    Matt34 Posts: 318
    edited June 2009
    treitz3 wrote: »
    you have come to the wrong board...
    As you and others have made clear many times over. Sorry I've wasted your time.
