Waxed the LSi's!
Ethancf
So the previous owner of my LSi25's managed to get a few scuffs on the ebony wood finish and on the black lacquer finish. I wasn't sure if I should have attempted this, but a bit of dark Old English finished the wood surface perfectly and a light compound with a caranuba paste wax shined up the black surface like a mirror!
Anybody else done this? My wife thought I had lost my marbles when she saw me waxing the speakers, but she was very happy with the finished product.
THE SYSTEM
Polk Audio LSiM 707 Mains
Polk LSiM 702 f/x Surrounds
Polk Audio LSiM 706 C Center
SVS SB-17 Ultra Subwoofer
Rotel RSP-1582 Pre/Pro
Rotel RMB 1585 Amplifier
Oppo UDP-205 Blu-ray Player
Samsung PN64D550 64" Plasma
Post edited by Ethancf on
Geez...apologies to the forum moderators...I meant to list this under the "Speakers" forum.THE SYSTEM
Samsung PN64D550 64" Plasma -
waxing the speakers is ok as the piano black finish is actually a basecoat/clearcoat catalyzed automotive finish. Once I found this out, I used a body shop to redo the finish on my damaged LSi15. They were kind enough to shoot it for free when they painted a black car.So the previous owner of my LSi25's managed to get a few scuffs on the ebony wood finish and on the black lacquer finish. I wasn't sure if I should have attempted this, but a bit of dark Old English finished the wood surface perfectly and a light compound with a caranuba paste wax shined up the black surface like a mirror!
Do you have any pics?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
nooshinjohn wrote: »waxing the speakers is OK as the piano black finish is actually a base coat/clear coat catalyzed automotive finish. Once I found this out, I used a body shop to redo the finish on my damaged Lsi15. They were kind enough to shoot it for free when they painted a black car.
Actually the Older models were lacquer or single stage black enamel and the newer ones were BC/CC...
Either or should play nicely with wax. A cleaner wax usually works best for taking out imperfections. I use Maguires.
Nick -
THE SYSTEM
If you want a real wet look that lasts longer try a sealant or polymer. Menzerna's Full Molecular Jacket is the only synethic wax that survives for longer than a couple months out in the 100 degree plus heat where I am. Another good option would be Optimum's Poli Seal. I have a ton of the FMJ laying around if anyone wants an ounce to try out. If you want to stick with storebought go with Klasse AIO, less greasy than a solid or liquid carnuaba.
I assume you are running them backwards? (so the woofers and tweeters are on the outside) They are quite shiny though....Mains.............Polk LSi15 (Cherry)
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Backwards? Subs are firing away from the wall unit. Left speaker is on the left side and right speaker is on the right side. Not sure I understand what you're asking.THE SYSTEM
Nervermind - sorry. I was thinking backwards.....Mains.............Polk LSi15 (Cherry)
I wish I had some before and after pics...ah well.THE SYSTEM
