is onkyo receiver capable of driving these speakers
ydglyd
ydglyd Posts: 4
edited June 2009 in Electronics
TX-SR806 receiver
Power Output -
Front L/R 130 W + 130 W (8 ohms, 20 Hz–20 kHz,
0.08%, 2 channels driven, FTC)
Center 130 W (8 ohms, 20 Hz–20 kHz, 0.08%,
Surround L/R 130 W + 130 W (8 ohms, 20 Hz–20 kHz,
Surround Back L/R 130 W + 130 W (8 ohms, 20 Hz–20 kHz,
Dynamic Power 300 W (3 ohms, 1 ch)
250 W (4 ohms, 1 ch)
150 W (8 ohms, 1 ch)
THD (Total Harmonic Distortion) 0.08% (Rated power)
Damping Factor 60 (Front, 1 kHz, 8 ohms)
Input Sensitivity and Impedance 200 mV/47 k-ohms (Line)
2.5 mV/47 k-ohms (Phone MM)
Output Level and Impedance 200 mV/470 ohms
Phono Overload 70 mV (MM, 1 kHz, 0.5%)
Frequency Response 5 Hz–100 kHz/+1 dB, -3 dB (Direct mode)
Tone Control ±10 dB, 50 Hz (Bass)
±10 dB, 20 kHz (Treble)
Signal-to-Noise Ratio 110 dB (Line, IHF-A)
Speaker Impedance 4 ohms–16 ohms or 6 ohms–16 ohms
Model LC80FX - Surrounds
Recommended Amplification 10-125W
(W/channel)
Impedance(Nominal) 4 Ohms
Frequency Response (+/-3dB) 30Hz – 27kHz
(45Hz-26kHz)
Efficiency (2.83V@1M) 88db
LC80i L/R
Frequency Response 30Hz-27kHz
Freq. Response -3dB Limit 45Hz-26kHz
Recommended Power 10-125Wrms
Impedance 4 Ohms
Efficiency (dB 1w/1m) 90dB 90
Model LCiC - Center
Recommended Amplification 10-150W
(W/channel)
(45Hz-26kHz)
Efficiency (2.83V@1M) 91db
I am trying to spec a Home Theater. Would this be an appropriate set up?
Post edited by ydglyd on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2009
    The Onkyo would really be struggling to drive a full setup of 4 ohm speakers. It's capable of driving 4 ohm loads, but it isn't really ideal.
    The 4 ohm setting on the 806 essentially limits the current, so that the AVR won't go into protect mode. This can really decrease the dynamics of the speakers, and isn't going to be pushing them to their potential.
    If you're set on those speakers and AVR, you may want to look into an external multi-channel amp.
    If you're looking into a 5.1 setup, you could either get a 5 channel amp, or get a 2 channel amp for the front left/right channels, and a 3 channel amp for the surrounds/center.
    Likewise, if you're looking into 7.1, you could get a 7 channel amp, or a 2 channel amp for the fronts, and a 5 channel amp for surrounds/center.
    Adcom, Rotel and Parasound all have great amps that won't break the bank, if you don't mind buying used.
    If you'd prefer new, you might look into Emotiva.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • ydglyd
    ydglyd Posts: 4
    edited June 2009
    thanks curt
    I am new to this and trying to learn before purchasing. Do preamps connect into the receiver?
  • comfortablycurt
    edited June 2009
    ydglyd wrote: »
    thanks curt
    The receiver is both a pre-amp and a power amp in one chassis. You'd want to look into power amps to connect to the receiver.
    There are also pre-amp processors, which are receivers without a power amp section. They require external power amps to drive your speakers.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited June 2009
    +1 on what Curt said, pretty smart guy that Curt. The Onkyo probably would be able to pull it off, but like he said you will be losing alot of potential in the speakers by using that Onkyo. However, you could like he said buy a decent amp and hook them up to the 806 and call it a day. I have the 806 and it is quite a solid unit, the speakers I have hooked up to it are 8 Ohm, so it does a fantastic job.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
