is onkyo receiver capable of driving these speakers
ydglyd
TX-SR806 receiver
Power Output -
Front L/R 130 W + 130 W (8 ohms, 20 Hz20 kHz,
0.08%, 2 channels driven, FTC)
Center 130 W (8 ohms, 20 Hz20 kHz, 0.08%,
Surround L/R 130 W + 130 W (8 ohms, 20 Hz20 kHz,
Surround Back L/R 130 W + 130 W (8 ohms, 20 Hz20 kHz,
Dynamic Power 300 W (3 ohms, 1 ch)
250 W (4 ohms, 1 ch)
150 W (8 ohms, 1 ch)
THD (Total Harmonic Distortion) 0.08% (Rated power)
Damping Factor 60 (Front, 1 kHz, 8 ohms)
Input Sensitivity and Impedance 200 mV/47 k-ohms (Line)
2.5 mV/47 k-ohms (Phone MM)
Output Level and Impedance 200 mV/470 ohms
Phono Overload 70 mV (MM, 1 kHz, 0.5%)
Frequency Response 5 Hz100 kHz/+1 dB, -3 dB (Direct mode)
Tone Control ±10 dB, 50 Hz (Bass)
±10 dB, 20 kHz (Treble)
Signal-to-Noise Ratio 110 dB (Line, IHF-A)
Speaker Impedance 4 ohms16 ohms or 6 ohms16 ohms
Model LC80FX - Surrounds
Recommended Amplification 10-125W
(W/channel)
Impedance(Nominal) 4 Ohms
Frequency Response (+/-3dB) 30Hz 27kHz
(45Hz-26kHz)
Efficiency (2.83V@1M) 88db
LC80i L/R
Frequency Response 30Hz-27kHz
Freq. Response -3dB Limit 45Hz-26kHz
Recommended Power 10-125Wrms
Impedance 4 Ohms
Efficiency (dB 1w/1m) 90dB 90
Model LCiC - Center
Recommended Amplification 10-150W
(W/channel)
(45Hz-26kHz)
Efficiency (2.83V@1M) 91db
I am trying to spec a Home Theater. Would this be an appropriate set up?
Power Output -
(W/channel)
(45Hz-26kHz)
LC80i L/R
Impedance 4 Ohms
Model LCiC - Center
(W/channel)
(45Hz-26kHz)
Post edited by ydglyd on
The Onkyo would really be struggling to drive a full setup of 4 ohm speakers. It's capable of driving 4 ohm loads, but it isn't really ideal.
The 4 ohm setting on the 806 essentially limits the current, so that the AVR won't go into protect mode. This can really decrease the dynamics of the speakers, and isn't going to be pushing them to their potential.
If you're set on those speakers and AVR, you may want to look into an external multi-channel amp.
If you're looking into a 5.1 setup, you could either get a 5 channel amp, or get a 2 channel amp for the front left/right channels, and a 3 channel amp for the surrounds/center.
Likewise, if you're looking into 7.1, you could get a 7 channel amp, or a 2 channel amp for the fronts, and a 5 channel amp for surrounds/center.
Adcom, Rotel and Parasound all have great amps that won't break the bank, if you don't mind buying used.
If you'd prefer new, you might look into Emotiva.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
thanks curt
I am new to this and trying to learn before purchasing. Do preamps connect into the receiver? -
thanks curt
The receiver is both a pre-amp and a power amp in one chassis. You'd want to look into power amps to connect to the receiver.
There are also pre-amp processors, which are receivers without a power amp section. They require external power amps to drive your speakers.The nirvana inducer-
+1 on what Curt said, pretty smart guy that Curt. The Onkyo probably would be able to pull it off, but like he said you will be losing alot of potential in the speakers by using that Onkyo. However, you could like he said buy a decent amp and hook them up to the 806 and call it a day. I have the 806 and it is quite a solid unit, the speakers I have hooked up to it are 8 Ohm, so it does a fantastic job.HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
