HDMI IN/HDMI OUT On Onkyo '605?
Mike LoManaco
Mike LoManaco Posts: 974
edited June 2009 in Electronics
Does anyone know if the current "600" line of Onkyos (mine's a '605) passes everything (video wise) that's sent into its HDMI IN through the HDMI OUT?
My Panasonic Blu-ray player is passing audio and video via HDMI to the '605's HDMI IN, and then another HDMI cable is going HDMI OUT from the '605 to my Sony SXRD display's HDMI IN...in this setup, should the video coming from the player pass straight through the '605 to the TV? Does anything -- aside from HDMI MONITOR: YES -- need to be set in the '605 to "tell it" to pass video straight through? Or does HDMI just automatically pass video through?
Post edited by Mike LoManaco on
  • izafar
    izafar Posts: 820
    edited June 2009
    605 passes through the HDMI as is. You still have to assign various inputs to devices like DVD , Cable/Sat etc.
    If you have connected the Blue-Ray to HDMI 1 in, and want to set it up as DVD player then you should have the following settings:
    Input/Output Assignment:
    HDMI Monitor = Yes
    HDMI Input Assignment
    DVD = IN 1
    Digital Input Assignment
    DVD = HDMI 1
    Video In = HDMI 1
    605 upconverts all analog signal to 540p by default. There is an un-document service menu setting that will allow it to upconvert to 720p. If you are using any analog sources then you should change this also.
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
  • Mike LoManaco
    edited June 2009
    Thanks For Your Help, Iz:
    izafar wrote: »
    Yes, I have all the assignments correct -- I just wanted to know if anything needed to be SET in the '605 to tell it to feed the video straight through its HDMI out...
    HDMI Monitor = Yes
    DVD = IN 1
    DVD = HDMI 1
    Yes, these are all correct and the same as you specify here, as I have the BD player set up as the "DVD" input for the receiver, under HDMI 1...
    Video In = HDMI 1
    Where is this setting? I don't think I recall a "Video In" menu...
    To 540p? That's an odd resolution; are you sure?
    I'm ONLY running HDMI...is there ANYTHING -- besides the HDMI MONITOR: YES and the IMMEDIATE DISPLAY: OFF -- that needs to be set to tell this receiver to pass that video from my BD player straight through?
  • izafar
    izafar Posts: 820
    edited June 2009
    If you are getting the picture from your Blue Ray then you are all set and don't need to change anything further. 605 doesn't have the ability to alter the HDMI signal, that's why you don't get on screen display with HDMI sources.
    -izafar
  • Mike LoManaco
    edited June 2009
    izafar wrote: »
    I do get an onscreen display with HDMI sources in the SETUP menu...
    But I'm wondering if anything needs to be "told" to the 605 in order that it knows just to pass video straight through...you're saying with HDMI, I don't need to?
  • Marty913
    Marty913 Posts: 760
    edited June 2009
    No, nothing needs to be told - the 605 passes the input HDMI signal to the output HDMI untouched. The onscreen setup menu originates from the 605.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited June 2009
    izafar wrote: »
    I was under the impression that the 605 only upconverted analog sources (component, composite, s-video) into digital (HDMI) forms, but kept the incoming resolution.
    The xx6 series however, I believe, have the ability to upconvert and UPSCALE, which is what I believe you are talking about.
    Feel free to correct me if I'm wrong. (If I am then it's good news, because I have the 705.)
    For example: I have an older DVD player that can only output 480p over component. When this is upconverted by my 705, the monitor (Samsung LN-T5265F) shows the inputted resolution as 480p @ 60hz.
    EDIT: sorry for the thread hi-jack OP, but hopefully this will help both us
  • Mike LoManaco
    edited June 2009
    Marty913 wrote: »
    Thanks Marty!
    But what do you mean, exactly, by "The onscreen setup menu originates from the 605"? As far as I know, there are only two "things" that need to be set up for HDMI passthrough, the HDMI MONITOR: YES setting and the IMMEDIATE DISPLAY: OFF setting...:confused:
