HDMI IN/HDMI OUT On Onkyo '605?
Mike LoManaco
Does anyone know if the current "600" line of Onkyos (mine's a '605) passes everything (video wise) that's sent into its HDMI IN through the HDMI OUT?
My Panasonic Blu-ray player is passing audio and video via HDMI to the '605's HDMI IN, and then another HDMI cable is going HDMI OUT from the '605 to my Sony SXRD display's HDMI IN...in this setup, should the video coming from the player pass straight through the '605 to the TV? Does anything -- aside from HDMI MONITOR: YES -- need to be set in the '605 to "tell it" to pass video straight through? Or does HDMI just automatically pass video through?
Post edited by Mike LoManaco on
605 passes through the HDMI as is. You still have to assign various inputs to devices like DVD , Cable/Sat etc.
If you have connected the Blue-Ray to HDMI 1 in, and want to set it up as DVD player then you should have the following settings:
Input/Output Assignment:
HDMI Monitor = Yes
HDMI Input Assignment
DVD = IN 1
Digital Input Assignment
DVD = HDMI 1
Video In = HDMI 1
605 upconverts all analog signal to 540p by default. There is an un-document service menu setting that will allow it to upconvert to 720p. If you are using any analog sources then you should change this also.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
Thanks For Your Help, Iz:605 passes through the HDMI as is. You still have to assign various inputs to devices like DVD , Cable/Sat etc.
Yes, I have all the assignments correct -- I just wanted to know if anything needed to be SET in the '605 to tell it to feed the video straight through its HDMI out...If you have connected the Blue-Ray to HDMI 1 in, and want to set it up as DVD player then you should have the following settings:
HDMI Monitor = Yes
DVD = IN 1
DVD = HDMI 1
Yes, these are all correct and the same as you specify here, as I have the BD player set up as the "DVD" input for the receiver, under HDMI 1...Video In = HDMI 1
Where is this setting? I don't think I recall a "Video In" menu...605 upconverts all analog signal to 540p by default.
To 540p? That's an odd resolution; are you sure?There is an un-document service menu setting that will allow it to upconvert to 720p. If you are using any analog sources then you should change this also.
I'm ONLY running HDMI...is there ANYTHING -- besides the HDMI MONITOR: YES and the IMMEDIATE DISPLAY: OFF -- that needs to be set to tell this receiver to pass that video from my BD player straight through? -
If you are getting the picture from your Blue Ray then you are all set and don't need to change anything further. 605 doesn't have the ability to alter the HDMI signal, that's why you don't get on screen display with HDMI sources.-izafar
I do get an onscreen display with HDMI sources in the SETUP menu...
But I'm wondering if anything needs to be "told" to the 605 in order that it knows just to pass video straight through...you're saying with HDMI, I don't need to? -
Mike LoManaco wrote: »I do get an onscreen display with HDMI sources in the SETUP menu...
No, nothing needs to be told - the 605 passes the input HDMI signal to the output HDMI untouched. The onscreen setup menu originates from the 605.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
I was under the impression that the 605 only upconverted analog sources (component, composite, s-video) into digital (HDMI) forms, but kept the incoming resolution.
The xx6 series however, I believe, have the ability to upconvert and UPSCALE, which is what I believe you are talking about.
Feel free to correct me if I'm wrong. (If I am then it's good news, because I have the 705.)
For example: I have an older DVD player that can only output 480p over component. When this is upconverted by my 705, the monitor (Samsung LN-T5265F) shows the inputted resolution as 480p @ 60hz.
EDIT: sorry for the thread hi-jack OP, but hopefully this will help both us -
Thanks Marty!
But what do you mean, exactly, by "The onscreen setup menu originates from the 605"? As far as I know, there are only two "things" that need to be set up for HDMI passthrough, the HDMI MONITOR: YES setting and the IMMEDIATE DISPLAY: OFF setting...
