Monitor 7C tweeter repair
MarkL
MarkL Posts: 4
edited June 2009 in Vintage Speakers
I blew both tweeters in my pair of sweet Monitor 7C's. What is the recommended part to replace them?
Post edited by MarkL on
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited June 2009
    Welcome to the Club.
    It's going to depend on which tweeters they are. Can you post pictures? If not look search the forum to find a picture of what you have and post it here and the guys will assist.
    What are you using to drive the 7's?
  • george daniel
    george daniel Posts: 12,096
    edited June 2009
    I can't remember,, are the 7c's fused? If so did you check them,,if not check the polyswitch??
  • MarkL
    MarkL Posts: 4
    edited June 2009
    Both tweeters play, but they are fuzzy and distorted. The other drivers seem fine. (I've blown out the mids before, many moons ago, so I know that that sounds like too!)
    I was driving them with a Carver Receiver 900 (90 wpc) in a 2-channel config. Was playing the "Eagle Eye" Blu-Ray on my brand new PS3. There's a scene early in the movie where the hero and heroine are fleeing in a car and someone shoots out the back window of their car. That gunshot is what caused the problem. :) Stupid Blu-Ray dynamic range!! :mad: :)
    I'll get some photos up promptly.
  • everpress
    everpress Posts: 862
    edited June 2009
    Polk lists these as having a recommended amplifier power of 20-150watts per channel.
    I'm new to the speaker scene, which will be more obvious by my next question:
    How do you blow speakers rated at 125 recommended watts with a 90 watt/channel receiver?
    And I'm asking because I have the rta-11tls rated to 250 watts and am pushing them with a very conservative HK receiver at may 65 watts/channel.
    ? Harmon Kardon AVR 55 (dead; replacing with Onkyo TX NR-616)
    ? Polk RTA 11TL's (FR and FL)
    ? Polk TSi200's (RR and RL)
    ? Polk CS10 (Center)
    ? Polk PSW-350
    ? Grado SR-60i Headphones
    ? Fii0 E5 headphone amp
    ? iPod touch (8 gig)
    ? iPod Classic (80 gig)
    ? Mac Mini (as media server)
    ? xbox 360
  • george daniel
    edited June 2009
    My guess is that you "clipped the amp", thus smoking your tweeters in the process,, careful with the volume Eugene,, or,, get a bigger/mo powerful/higher current amp,, you'll do far less damage than you will underpowering IMHO--good luck.
  • ben62670
    ben62670 Posts: 15,969
    edited June 2009
    Call Polk CS. You may have the SL2500 in those, and the new replacements are the RDO-198's. If they are the SL2000's the replacement part is RDO-194's. Mention that you are a Club Polk member to get the discount;)
    Take care.
    Ben
    Ben
  • MarkL
    MarkL Posts: 4
    edited June 2009
    I'm quite certain that's exactly what happened. That Carver is a real trooper, but the transients in that gunshot probably caused it to clip for an instant.
    My long-term goal is to upgrade, but budget is tight, so a tweeter replacement and some caution in the volume department is all I can do for now. I've got a line on a used Sunfire Cinema Grand 5x200, keeping my fingers crossed....
  • NJPOLKER
    edited June 2009
    You will want to fix the problem before buying new tweeters or you will literally blow
    $100.
  • MarkL
    MarkL Posts: 4
    edited June 2009
    OK Here is a pic of my tweeter. However, while taking this pic, I noticed a small tear in the rubber surround of the midrange driver. I hadn't even seen it before. I've attached a pic of that too. What's really weird is ... when I checked the other speaker, THAT midrange had exactly the same kind of tear is exactly the same place!
    Is a small tear in the surround something that would lead me to need to replace those too? If I have to replace enough stuff, I might be getting into just replacing these with something new (and then repairing them later! ha)
  • skrol
    skrol Posts: 3,446
    edited June 2009
    Those butchers!
    It is a lot to have to replace tweets and MWs all at once. You could try a little rubber cement on the tears. Just a little along the edge of the tear and mate the edges together. No glops. It may not be optimal but it should get you playing for a while. Then replace the MWs later (unless you really want something new).
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • NJPOLKER
    edited June 2009
    You can buy a pair of tweeters from Polk for around $100. shipped. You want the
    RDO-194's and be sure to tell them you are a memebr of this wonderful forum. They do sound nicer than the SL-2000's you are replacing. Remember that they take a little time to break in. Try and be careful with the volume or you may blow the RDO's.
    It may be a good idea to look into something like a integrated amplifier. A good one can be found for around $200.
    Good luck
  • NJPOLKER
    edited June 2009
    Did you buy it yet?? Don't wait too long!
