Brought my system...
phongnguyent
After a week or two of research and help from ya... i can now say that i ordered my stuff.. and the system is coming..
I want to have special thanks to everyone especially Powered again for helping me out... he configured at least 4 systems for me.. (that fit my interest)
So i ordered...
(1) Image Dynamics ID MAX 12 v.3 D4
(1) Phoenix Gold T1200.1 Renewed
(1) Rockford Fosgate Type RF CP2POS if i am correct
and im gettin hooked up from powered a custom box for my 12...
I can now say that my wallet is gone :P
Well, i can't wait till all these stuff is in my 4runner working :P
After this... front & rear speakers and headunit and another amp...
Ahhhhhh... the hobby of car audio :P
BOOM BOOM BOOM...
So i ordered...
BOOM BOOM BOOM...
Post edited by phongnguyent on
*waits to be pummelled by those objecting to my choices*
*looks around... hmm, no pummelling yet... maybe i'm safe*The Artist formerly known as PoweredByDodge -
LoL power.. i just got the sub today.. my god is it heavy
heh heh heh -- i told you so...
you could do bicep curls with it... 40 lbs ain't light.
sent u an email -- box will be done on wednesday as i recvd your payment today... have a bunch of **** to do tomorrow so it'll get finished wednesday.The Artist formerly known as PoweredByDodge -
Np my friend.. and thanks again.. take your time :P
The ups guy was like this sub is underweighted... lol i think carmedia weighted it as like twenty something pounds.. they must got someone working inside ups.. -
heh heh heh heh .... i think mine came to like 43 pounds with the sub and the cardboard box they were in.
20 something is VERY underweighted.The Artist formerly known as PoweredByDodge -
the mm12s only weigh 15lbs...
i thought my box was heavy at 87lbs
if i had two 43 lb subs itd weigh 143lbs
lol
-Cody -
she's done -- in the mail in the morning.
once again thanks :P
Also you said predrill the holes.... didn't you make the holes in the box already? You said you made 8 holes... what do you mean exactly when you say "predrill"?
Thanks.. im not a handy guy and jus dont wanna mess up your creation :P
Also, about screw and the mounting thing... my sub did not come with any... if you have can you put it in.. or if i need to buy please just let me know its np..
Thanks again power
Owe you another one..
After this i got one more project for you :P -
i'll send ya bolts and gasket material.
i didn't drill any holes in the mount space -- you've gotta lay the sub in the box, and with the sub IN THE BOX carefully predrill 8 very small holes --- just go right through where the screw holes in the basket of the sub are... then u put the screws in and call it a day.
if i were to predrill them now, chances are they'd be off by a little. the basket of the idmax isn't a standard 12" sub basket. its a little tiny bit oversized.The Artist formerly known as PoweredByDodge -
Uh, I wouldn't drill any holes anywhere near a speaker.
Goto an office supply store and pick yourself up a Sharpie permanent marker. I say Sharpie becayse they have fine pointed markers that will write on anything. Go home, take your sub, drop it in the box and then mark the holes with the sharpie. Then pull the sub out, drill your holes, lay your gasket around the edge, put the sub back in and screw the **** down good.
This ensures that you will not damage the speaker cone with your power tools or screw drivers. I know first hand that speaker warranties do not cover boneheaded stunts.
It just says something for Kenwood that the 8 inch sub I cracked after poking with a slipping screwdriver, didn't disintigrate. It took somebody dumping brake fluid and cleaner on it accidentally to destroy it.Expert Moron Extraordinaire
.. good point john.
brake fluid.... jesus... worst i ever dumped on a sopeaker was kool-aid -- goddamn thing was sticky for like ever.The Artist formerly known as PoweredByDodge -
Haha.. so far 6 hrs of work in this stupid car.. 2 days so far
Reasons? Couldn't find the amp on first day.. but ran all the wires except the remote and speaker..
also found out the amp did not had hi input levels.. so i needed to buy converter and rcas... well at least i did not know how to use the hi level...
2nd.. found another way... soldier in the speaker wires and connect to 16gauge into converter.. then to rca to amp
on process found amp but was underneath airbag and didnt wanna mess around.. so stayed with the assumption
connect power to battery.. and the moment of truth and NO SOUND!!
Amp was not turned on.. then we tested the wires.. all was ok except remote! So we thought oh **** we hooked the remote to antenna...
so turn on radio and blam... boom boom boom
so tomorrow gonna redo the remote.... so far system sounds pretty good.. thanks power..
power's box is awesome... sub is working ... amp is good so far
there goes my sound speaker :P -
got it perfected..
gonna try tuning it better... tomorrow...
idmax... is awesome.. i dont know much about speaker but one of them hit like crazy..
thanks power agian :P
