LSi7 Crossover upgrade?
Stevenmbell
Has any one done a crossover upgrade on there LSi7's? If so can you help me out? Thank you Steve
2 CHANNEL:cool:
Belkin PF31Pure power/AV Conditioner
NAD C165BEE PreAmp Great Phono Section
B&K ST1400 S2 Power Amp
Audio Quest 4 Speaker Cables
ProJect RPM 1 Carbon
Ortofon Blue Cartridge
Quadio Interconnects
Denon 2910 DVD-A/SACD Player
Pangea SE 14 & AC9 Power Cords
Vifa DIY 3 ways Sound is incredible. :biggrin:
Post edited by Stevenmbell on
I have not yet, but it is the next upgrade on my list. (waiting for the next SonicCraft sale)
Anyway - what do you need?Mains.............Polk LSi15 (Cherry)
Just wanted to know if you stayed with the same values in your caps or did you change them? What were your results?2 CHANNEL:cool:
Vifa DIY 3 ways Sound is incredible. :biggrin: -
I have done an LSiC crossover upgrade (with very good results) and expect even better results from the LSi7 upgrade (due to the crossover design and values)
I (and most people I think) stick with the same values for the components and just use higher quality ones. I repace the caps with SonicCaps and the resistors with Mills. You could also change out the inductors, but I have not gone that far.
Good luck with the upgrade and take lots of pictures. Any other questions, just ask.
They may have one soon. I noticed when PartsConnexion has a sale, Sonic Craft usually follows and vice versa.(waiting for the next SonicCraft sale)
As for changing values, if you have to ask...don't. An air core inductor for the woofer wouldn't be a bad idea, but make sure the DCR is the same or very close to the OEM value.
The rest depends on your budget."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
How much experience do you have with a soldering iron?
Very good point.
If you have soldered before, I can't see the LSi7 being that much of a problem. Not like an LSi15 or an RTiA9Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
What'd I tell ya?They may have one soon. I noticed when PartsConnexion has a sale, Sonic Craft usually follows and vice versa.
http://soniccraft.com/index.htm"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
What'd I tell ya?
Parts Ordered - Thanks Face.....Mains.............Polk LSi15 (Cherry)
I did not want to muddy up your thread with my own upgrade so I started my own here.....
If you have any specific questions, just ask and I will make sure I get a photo of it as I work on mine. I expect to start the work on mine next week sometime, so you have until then for any preemptive type questions.
Have you ordered your parts yet for the upgrade? What did you end up getting?Mains.............Polk LSi15 (Cherry)
