comp space
Systems
I was wandering if component speakers could be placed near each other. I have a big gap where the cup holders would be at the bottom of the center column, below the radio and vent controls. I want to have them facing away from each other (one facing the driver and one the passenger), but then the magnets would be close and I was wandering if the electromagnetic field from one would effect opperation of the other?
Testing
Testing
Testing
Testing
Testing
I've seen setups in Jeeps and things with comps and coax's setup similarly to that in a panel on the ceiling. I don't think it will be a problem. Unless the comps are close to your deck or a monitor."The Big C"
How close is "close?" Like in ft. or something.Testing
Testing
Testing -
Something similar to like how you wanna keep magnets away from a tv. If you set your comps in the car roughly where you will be installing them and it doesn't look like the colors/display of your deck or monitor are smearing you should be alright. Probably just a foot or so would be enough distance."The Big C"
as long as their not touching each other you're fine.The Artist formerly known as PoweredByDodge
